Spark plug
Old 05-09-2008, 07:31 PM
stanglover1250
stanglover1250's Avatar
Default Spark plug
What is the best spark plug for my car? should i go for copper, platinume, or iridium?
stanglover1250 is offline
Old 05-09-2008, 07:35 PM
fordforlife0225
fordforlife0225's Avatar
Default RE: Spark plug
same question for me i have a stock 04 v6 stang with 90,000 miles and its about time to change the plugs, looking for something good to go with my soon to be dual exhaust, intake, and tuner
fordforlife0225 is offline
Old 05-09-2008, 10:02 PM
stanglover1250
Anyone?
Old 05-10-2008, 01:13 AM
SilvrStang
SilvrStang's Avatar
NGK T455s work awesome. I have them on my GT and Im very happy with them.
SilvrStang is offline
Old 05-10-2008, 04:15 AM
NeoTokyo
NeoTokyo's Avatar
Stock Ford equipment is Platinum plugs. I would stick with that.
Also the drivers side uses different plugs than the pass side due to the coil pack design.
The reason for this is due to the Wasted Spark ignition system.
Here are the part numbers you need if you want to stay stock platinum plugs.
Left side cyl 1-2-3 : AWSF-42E
Right side cyl 4-5-6 : AWSF-42EG
They are different because of again the WSI mentioned up top, so one has plat on the electrode and the other plat on the tip. This saves ford a couple cents in platinum but it adds up for those cheap ol guys.
These plugs are a direct replacment and have plat tips and electrodes and can be used on both sides. This is the most common choice and easiest.
Plat Tip and Electrode plugs: AWSF-42EE
Another choice you have is to run copper plugs which run just fine and are half the cost.
Copper Plug: AWSF-42C
I have been running NGK V-Power copper plugs in the ol nag and they run fine. I just pulled them the other day and they are in perfect condition.
Another expensive option to go by is the Motocraft Fine wire platinum plugs, but those are $5 dollars each and if you go to NGK Iridium then you spend $8 bux each.
I like my $1 dollar NGK's LOL (DOH! They rose the price to $2 dollars! B@STARDS!)
NeoTokyo is offline
Old 05-10-2008, 05:47 AM
RyansQuick6
Reverse Gear Member
RyansQuick6's Avatar
My $12 a piece NGK's are all the same part number and work friggin awesome
RyansQuick6 is offline
Old 05-10-2008, 12:59 PM
ESG-642T
Buyer Beware
ESG-642T's Avatar
ORIGINAL: RyansQuick6
What NGK's are 12$ each!!!
ESG-642T is offline
Old 05-10-2008, 01:31 PM
Matt's 95 Stang
Resident Ginger
Matt's 95 Stang's Avatar
I have Autolight Double Platnum in mine and havent had a problem yet. They cost me $25.97 for 8.
Matthew
Matt's 95 Stang is offline
Old 05-10-2008, 01:42 PM
ayrton02
ayrton02's Avatar
I have Denso iridiums, they are great. Just don't get Bosch - they suck.
ayrton02 is offline
Old 05-11-2008, 03:25 AM
NeoTokyo
NeoTokyo's Avatar
What, no "MAKE THIS A SPARK PLUG STICKY!!!"
lol you people dont respect me anymore :P
PS. When I get the Accel coil pack, plug wiresand/or DIS-4 I will upgrade to iridium, but thats $60 dollars I dont want to spend just yet.
NeoTokyo is offline
Quick Reply: Spark plug
