Where is the Starter Relay???
Old 05-14-2008, 11:19 AM
OneFastEclipse
OneFastEclipse's Avatar
Default Where is the Starter Relay???
On a 94 Mustang GT, where is the Starter relay? I picked one up at the parts store to replace it and can't find the damn thing anywhere. All references I find say its on the drivers side fender, I see nothing there. Maybe I'm just blind.
OneFastEclipse is offline
Old 05-14-2008, 11:24 AM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
Default RE: Where is the Starter Relay???
THE SELONOID on 94-95 is incorporated down on the starter
mjr46 is offline
Old 05-14-2008, 12:27 PM
OneFastEclipse
I assume I have to remove the whole starter to get to that? Is it just two bolts holding the starter on?
Old 05-14-2008, 12:42 PM
Joel5.0
Joel5.0's Avatar
There's a 12-vdc Bosch relay in the underhood power distribution/fuse box.......
Joel5.0 is offline
Old 05-14-2008, 12:59 PM
OneFastEclipse
Ha, very nice. That may be a bit easierr to replace . Thanks for that
Old 05-14-2008, 05:23 PM
OneFastEclipse
Well the relay didn't fix it. Guess it is probably the solenoid on the starter itself. Of course it couldn't be the easier of the two....
Old 05-14-2008, 05:25 PM
mjr46
mjr46's Avatar
did you test the clutch switch???
mjr46 is offline
Old 05-14-2008, 06:06 PM
OneFastEclipse
No I didn't, how you go about doing that?
Old 05-14-2008, 06:55 PM
Joel5.0
Joel5.0's Avatar
Want to check the starter w/out removing it?....... remove the starter relay from the underhood fuse box, make sure transmission is in neutral, IGN OFF, and place a wire jumper between the relay socket terminals shown below.......
If starter is toggled this way, like MJ said, the clutch switch circuit needs to be checked.
[IMG]local://upfiles/27355/8D791C079C0E4CDA9AF185A0C5BC6DC1.jpg[/IMG]
Joel5.0 is offline
Old 05-14-2008, 07:25 PM
OneFastEclipse
ORIGINAL: Joel5.0
I just did that and it does in fact toggle the starter. How do I test the clutch switch?
Quick Reply: Where is the Starter Relay???
