fuel line coupling replacement??
Old 05-22-2008, 11:48 PM
tofast4u1989
tofast4u1989's Avatar
Default fuel line coupling replacement??
my friend who is a mechanic thinks he is a know it all. when doing the fuel filter change on my 2005 gt he thought that the fuel line coupling that went from the fuel fitler to the fuel line needed to be picked instead of using my fuel line tool. after it didnt work i tried my fuel line trick and it worked. after hooking back up it didnt leak or anything. 5 minites later gas leaked so had to adjust the coupling and i think it might be messed up. does ford sell just the black plastic piece that has the green lock that goes from the filter to the fuel line???
tofast4u1989 is offline
Old 05-22-2008, 11:58 PM
tofast4u1989
Default RE: fuel line coupling replacement??
i meant to say that i think the piece can also be reffered to as a fuel fitting?
Old 05-23-2008, 01:51 PM
jerjan
jerjan's Avatar
Don't really know, You probably should call a Dealer.
jerjan is offline
Old 05-23-2008, 02:48 PM
157dB
Cut & Paste Expert
157dB's Avatar
I wouldnt be messin around with fuel leaks.
Its fine then starts leaking 5 mins later?
Unpredictable fuel leaks are the worst kind.
Couplings should never need to be"adjusted"
to correct leaks. They are either properly
connected or they are not.
Get it repaired at the dealership and send
the bill to your knowitall mechanic friend.
Today on the Peoples Court......
But judge, he said he knew what he was doing.......
157dB is offline
Old 05-23-2008, 02:55 PM
partsbill
partsbill's Avatar
no serviceable parts, only complete fuel line assy
with 4wabs ford part# 5R3Z 9J279-A retail $184.00
without 4wabs part# 5R3Z 9J279-B retail $169.98
partsbill is offline
Old 05-24-2008, 11:24 PM
fosman77
fosman77's Avatar
Do we need a tool or not? What is your trick?
fosman77 is offline
Old 05-25-2008, 07:45 AM
partsbill
partsbill's Avatar
[*]Press the quick connect coupling release tab and pull the tube to disconnect.[*]
[IMG]local://upfiles/31978/DAE1AC24554547119F2B09A9CBF3ED0F.gif[/IMG]
Old 05-25-2008, 04:24 PM
fosman77
fosman77's Avatar
Thanks, Fosman
fosman77 is offline
djbigskrilla
09-20-2022 01:04 AM
Design1795
01-24-2017 10:38 PM
Calizic
08-28-2015 01:46 PM
1st 4 eyed fox
08-24-2015 06:56 PM
Soldier GT
08-12-2015 03:46 PM
Quick Reply: fuel line coupling replacement??
