Hissing noise after I turn off my car?
Old 05-24-2008, 05:14 PM
Andy13186
Andy13186's Avatar
Default Hissing noise after I turn off my car?
My car makes a hissing noise for a while after i turn it off, is this normal or is there some type of leak? it seems to run fine etc... no visible liquid leaks. Is this just a normal cooling noise?
Andy13186 is offline
Old 05-24-2008, 05:27 PM
jrherald420
jrherald420's Avatar
Default RE: Hissing noise after I turn off my car?
not sure what it is but mine does it also its normal
jrherald420 is offline
Old 05-24-2008, 05:38 PM
02 Ninja
02 Ninja's Avatar
A cobra makes a hissing sound. Maybe the 2v is throwing some hints at you....................4v maybe????
02 Ninja is offline
Old 05-26-2008, 09:14 AM
retmil
retmil's Avatar
If you are hearing that noise after you have been driving with the AC on, it is water dripping from the drain onto the exhaust.
retmil is offline
Old 05-26-2008, 09:23 AM
oxfordgt
oxfordgt's Avatar
The hissing sound is air coming back through the Tb after the car is shut off and there is no vacum anymore. Normal
oxfordgt is offline
Old 05-26-2008, 12:29 PM
TeamCobra
TeamCobra's Avatar
Haha, a Cobra makes a hissing sound, that's great. Is the hissing coming from you expansion tank? (coolant) if so, oh no!
TeamCobra is offline
Old 05-26-2008, 02:17 PM
mustang_pa
mustang_pa's Avatar
ORIGINAL: retmil
+1
mustang_pa is offline
Old 05-26-2008, 02:52 PM
Frptsx
Frptsx's Avatar
Mine makes the hissing when I had the AC on for a bit.
Frptsx is offline
Old 05-26-2008, 09:01 PM
will
will's Avatar
If the noise is comming after you run the ac then its the hig and low side pressures equalizing
will is offline
djbigskrilla
09-20-2022 01:04 AM
92 5.0stang
08-13-2015 06:46 AM
Milan Dragway
08-12-2015 03:43 PM
yurizx6r
08-11-2015 07:50 AM
Daleford
08-10-2015 08:30 PM
Quick Reply: Hissing noise after I turn off my car?
