Best way to change the PCV valve?
Old 04-28-2005, 01:26 AM
bobby
bobby's Avatar
Default Best way to change the PCV valve?
well, i got a new one today, never been changed... 111k miles well, i see its tucked up under the intake nicely just to make it a pain to get to it! is there any tricks to getting it off? or is it just beter to pull the intake? thanks a lot guys!
bobby is offline
Old 04-28-2005, 03:39 AM
silver91gt
silver91gt's Avatar
Default RE: Best way to change the PCV valve?
just put your hand behind the intake, and follow the hose, it comes out at the back of the driver valve cover area. then pull it up, the hose will turn when u pull up on it.
just make sure the gromet stays in there, it doesnt matter if it comes out, just dont lose it.
silver91gt is offline
Old 04-28-2005, 04:36 AM
luckythirteen13
luckythirteen13's Avatar
are you removing the actual valve or just the screen? either way, you can do it without taking the manifold off. you should be able to just reach down there and pull it out
luckythirteen13 is offline
Old 04-28-2005, 08:40 AM
stanglx2002
stanglx2002's Avatar
when you pull out the PCV valve you should pullout the grommet and pull the screen out thats below it and clean the crap out of it bc it will probably very dirty
stanglx2002 is offline
Old 04-28-2005, 10:34 AM
86HOGT
86HOGT's Avatar
Come one bobby, get your hands dirty! There's not even one bolt you have to loosen.
86HOGT is offline
Old 04-28-2005, 07:55 PM
bobby
bobby's Avatar
LOL, im confused, so theres a screen and stuff to i should replace? do i just pull everything out?
bobby is offline
Old 04-28-2005, 08:11 PM
88PatrolCar
88PatrolCar's Avatar
You should replace the screen also. Pull the pcv out then the grommet and you can use a bent paper clip to pull the screen out
88PatrolCar is offline
Old 04-29-2005, 12:46 AM
bobby
bobby's Avatar
allright cool, thanks!
bobby is offline
Old 04-29-2005, 02:36 AM
GT350Stang
GT350Stang's Avatar
that is why i love my carb. car my PCV is right up front on the front part of the driver side valve cover
GT350Stang is offline
Old 04-29-2005, 11:08 AM
bobby
bobby's Avatar
ya guys, lol, carbs are easy to work on, but you cannot beat EFI! lol
bobby is offline
LivingInThePast
09-16-2015 12:20 PM
EASTIDEE123
09-14-2015 03:52 PM
TfcCDR
09-14-2015 12:08 PM
Scottyboy187
SVT Forums
09-13-2015 10:23 PM
Quick Reply: Best way to change the PCV valve?
