Street/Strip Raced a guy from a light? Had that ride of yours on the timed track? Tell your story here.
Drag Slicks
Old 06-17-2008, 10:26 PM
Pauly_B
Pauly_B's Avatar
Default Drag Slicks
Few q's got a 03 Mustang GT what size rims and slicks can i use on this car, well thats the best set up? There are 17's street tire on there now.
Thanks Guys and Gals
Pauly_B is offline
Old 06-17-2008, 11:24 PM
USMCrebel
Mach I Section Moderator
USMCrebel's Avatar
Default RE: Drag Slicks
i would go with 15" rim with 10" of tire...you'll hook and break ****
USMCrebel is offline
Old 06-18-2008, 10:20 AM
Blownsvt
Blownsvt's Avatar
you defnintly need a 15' heel, how wide is up to you but alos depends on your power level. I would not go much taller than a 26" tire. what gears are you running?
Blownsvt is offline
Old 06-18-2008, 10:23 AM
USMCrebel
USMCrebel's Avatar
whats done to your cobra, and is those #'s on race gas?
Old 06-18-2008, 10:49 AM
Blownsvt
Blownsvt's Avatar
not to hijack the thread but.
ok here we go...........
2003 cobra
283 CI (stock block bored .20 over)
CP 17cc dished pistons
Hellion single turbo kit
Turbonetics T-76 s-trim turbo
accelleron 96lb injectors
accelleron driver box
Aeromotive eliminator return fuel system with eliminator pump
accufab twin 62mm throttle body
UPR tubular K-member
coilover front suspension with blistein shocks
magnaflow wide open exhaust with turndowns before the rear axle
Solid axle swap- Ford 9"
3.25 gear ratio
35 spline axles
Detroit locker locking unit
GT rear brakes
Blistein rear shocks
BBK loweirng springs in the rear
4" (i think) aluminum 1 pc drive shaft.
Ram street dual 300 series clutch
26 spline input shaft
stainless steel TOB retainer
sumped fuel tank
KB boost a pump
steeda tri ax shifter with mgw adjustable blue handle
3 gauge a pillar pod
AEM Eugo wideband
AEM true boost gauge with built in boost controller
Aeroforce obd2 scan gauge
Raptor pencil LED shift light
35mm integrated spacers
Weld prostars 15x10 and 15x 3.5
28x10.5 -15 MT ET DRAGS
25x4.5 - 15 MT ET DRAG skinnies
SCT X-calibrator 2 software
I think that is most of it anyway
those numbers are on 110 octane fuel. I rin 110 all the time so thats how it gets street driven. i plan to shim the wastegate and add boost and mybe c-16 here soon. and see how it does.
Blownsvt is offline
Old 06-18-2008, 10:53 AM
USMCrebel
USMCrebel's Avatar
thinkin about it, im thinking he might need the 15" with 9" of tire, i dont think 10 would help much more.
Old 06-18-2008, 11:03 AM
Blownsvt
Blownsvt's Avatar
rule of thumb the bigger and taller the tire the better it will hook. but if his trap speed is not super high and not limited by gearration i would not go to a 28" tall tire stay with the shorter on for less rotating mass. It takes more power to turn the larger tire so if you are not limited by gear ratio idealy you get the smallest tire that you can hook on. i went to a 28" tire because with the 3.25 gear ratio we think it will put me through the traps at the top of 4th at around 145mph or so. have not been able to test it yet because the car is still getitng the cage put in it.
Blownsvt is offline
Old 06-18-2008, 11:06 AM
USMCrebel
USMCrebel's Avatar
yeah the balancing act of rotational mass is a bitch.....he might be stock though and that would really hurt him
Old 06-18-2008, 11:28 AM
Blownsvt
Blownsvt's Avatar
if it is stock, i would look at getting a 15 inch wheel and then put a 26" MT et street DOT cheater slick on it. something in about a 255 or so.
Blownsvt is offline
Old 06-18-2008, 11:29 AM
USMCrebel
USMCrebel's Avatar
^ that would be good for a bone stock new edge.
Quick Reply: Drag Slicks
