bad sputtering and backfiring problems....
Old 06-18-2008, 10:38 AM
8850gt
8850gt's Avatar
Default bad sputtering and backfiring problems....
well my girl is gettin sick whenever i start her up she starts fine. then then rpms come down after the initial rev and flucuate from 600 rpm to about 900 rpm. when this is happening the oil pressure gauge jumps around randomly, but never goes below the red line at the bottom... now if i put my foot on the gas bringing the rpms up to about 1200 it will stay steady. if i dont warm it all the way up to normal running temp before i start driving it will backfire badly in second gear when im accelerating. it even backfired in 4th gear yesterday and even after it warmed up it backfired. im not sure whats going on, was wondering if anyone else has had this problem before. i put new plugs, wires, and distributor cap in it about a year ago. im guessing its not that. its frpp 9mm wires, oem plugs and msd cap. also im not sure if this is related but the other day i stoped suddenly and my car stalled, when it did the amp light and the check engine light came on. i restarted it and they both went off... anyways if anyone has any ideas what it could be im all ears... btw its an 88 gt with stock engine, either 330k miles or 230k, but the previous owner said it was rebuilt.... i dunno any help would be greatly appriciated... thank you
8850gt is offline
Old 06-18-2008, 10:40 AM
1fastzook
1fastzook's Avatar
Default RE: bad sputtering and backfiring problems....
I would check engine codes and do a cylinder balance test.
1fastzook is offline
Old 06-19-2008, 05:56 AM
8850gt
8850gt's Avatar
the check engine light isnt on, so i dont know if any codes will pop up....
8850gt is offline
Old 06-19-2008, 06:11 AM
stang8689
stang8689's Avatar
I would clean the IAC first and check your TPS voltage
stang8689 is offline
Old 06-19-2008, 06:34 AM
Joel5.0
Joel5.0's Avatar
ORIGINAL: 8850gt
The only way to find out is by running a DIY KOEO/KOER/Cylinder Balance Self-Test .... there are failure codes that will not cause the CEL to turn on, you should also verify the basic items...... fuel pressure, initial timing. Regarding the TPS..... if you don't have a TPS related failure, it's OK.... no need to adjust a non-adjustable sensor if the EEC sees it doesn't have a problem. LUK
Joel5.0 is offline
Old 06-19-2008, 11:19 AM
Alero99
Alero99's Avatar
i guessing its a 1988
ther is no CEL on the 87 and 88s, there is no bulb in there from the factory...
run the KOEO KOER tests.
Alero99 is offline
Old 06-19-2008, 01:26 PM
brentloftis
brentloftis's Avatar
88, speed density or converted to MAF? Mine was doing similar things and eventually found it to be vacuum related to the hose to the MAP being old and rotted. Mine was a pin hole leak and it made the car run like crap and misfire here and there and buck around. Replaced the hose and presto runs like a champ... well a ugly partially paint stripped, old rotted tires, ripped top champ anyway
brentloftis is offline
Old 06-19-2008, 01:38 PM
8850gt
8850gt's Avatar
its converted to maf, how would i check for the vaccum leak? it only does it when i first start up, and it doesnt do it everytime. sometimes when i start it up, it runs fine... and sometimes its worse than other times...
8850gt is offline
Old 06-19-2008, 01:45 PM
brentloftis
If its been converted clean IAC and MAF first, verify the spliced in pigtail wiring has not come loose. There are many ways to check a vac leak, everyone like something different. Professionals use smoke, some spray a shot of carb cleaner around suspected areas, I personally use a plumbers torch witha rubber hose.Iturn on the valve and move the end of the hose around the vacuum hoses and ports and listen for a change in the idle...
Old 06-20-2008, 05:28 AM
8850gt
8850gt's Avatar
ug, im not very good at doing this kind of troubleshooting think it would be a good idea to take it to my mechanic? just dont want him to give me alaundry list of stuff i dont really need to fix....
8850gt is offline
Quick Reply: bad sputtering and backfiring problems....
