Sponsored by: DashLynx
Ignition switch stuck-wont turn to on
Old 06-21-2008, 06:46 PM
samstang
samstang's Avatar
Default Ignition switch stuck-wont turn to on
Hi,
I have a 1998 mustang 3.8 convertible,and the ignition is now stuck in the off position and will not turn to on, or start with the key. I've tried turning the wheel back and forth with the key in but that also is locked ,and the transmission is also locked in park. Any Ideas how to free up this locked up state? Do I need to replace the switch?
Thanks
sam
samstang is offline
Old 06-21-2008, 07:04 PM
akp20032004
akp20032004's Avatar
Default RE: Ignition switch stuck-wont turn to on
Did you try to wiggle the wheel back and forth and try the ignition at the same time. Mine does that from time to time. Even though your steering wheel is locked you should still be able to move it back and forth a little bit.
akp20032004 is offline
Old 06-21-2008, 08:27 PM
samstang
samstang's Avatar
yes,it will not unlock at all.
samstang is offline
Old 06-22-2008, 06:01 PM
Sunadaime
Sunadaime's Avatar
Stick your key in pull the steering wheel to one side as much as it will budge and try to start the car at the same time. I have to do this sometimes.
Sunadaime is offline
Old 06-22-2008, 06:45 PM
Stepman
Stepman's Avatar
Squirt some WD-40 into the lock. The pins may have stuck..or your key may be worn. Then, wiggle the key up and down as you move it in and out to loosen them up.
Stepman is offline
jma2
07-10-2023 01:00 AM
Meystang
09-25-2015 04:05 PM
pimp2303
09-17-2015 08:45 PM
TfcCDR
09-14-2015 12:08 PM
Wombatnation
09-13-2015 09:16 PM
Quick Reply: Ignition switch stuck-wont turn to on
