Brake Bleeding?
Old 06-23-2008, 05:13 PM
boogerschnot
boogerschnot's Avatar
Default Brake Bleeding?
Should I bleed the lines with the car running or not in a Power brake system..
boogerschnot is offline
Old 06-23-2008, 05:38 PM
rmodel65
Yukon Cornelius
rmodel65's Avatar
Default RE: Brake Bleeding?
i always do it with the car off, no reason to waste fuel
rmodel65 is offline
Old 06-23-2008, 05:53 PM
Starfury
Starfury's Avatar
Also makes it easier to get 'real' pedal feel, that way you can tell the difference between spongy and firm, whereas the power booster would make that rather difficult.
Starfury is offline
Old 06-23-2008, 06:18 PM
UH60LCHIEF
UH60LCHIEF's Avatar
I've never bled it with the engine running and I've never had a problem.
UH60LCHIEF is offline
Old 06-23-2008, 06:48 PM
kalli
kalli's Avatar
no question about that. engine off.
The booster is only there to make it a bit easier on your foot.
makes no difference in the bleeding process (how much air is going out at what rate).
And as Tad says with powerbrakes you never know if the thing is properly bled.
So aye .. leave engine off
kalli is offline
Old 06-24-2008, 10:13 AM
boogerschnot
Thanks guys.. I bleed the lines tonight.
Old 06-24-2008, 10:56 AM
kalli
kalli's Avatar
when you don't have any speed-bleeders or bleeding container, then you'll need someone else to help you.
Do you know exactly how the bleeding process works (just to make sure)
Kalli
kalli is offline
Old 06-24-2008, 01:26 PM
boogerschnot
Yea, Ive done it a couple of times, I just didnt know if I should run the car or not. I figured not.. but had to be sure.
The wife is going to be my pedal pusher..
Old 06-24-2008, 03:24 PM
jlg2002
jlg2002's Avatar
don't forget to ask her if "it's hard yet"[sm=roll.gif]
jlg2002 is offline
Old 06-24-2008, 04:14 PM
Oxnard Montalvo
Oxnard Montalvo's Avatar
ORIGINAL: jlg2002
LOL
Don't be short with her if she screws up somehow, if you do it won't matter how hard "it" is, you'll be on your own.
Oxnard Montalvo is offline
Quick Reply: Brake Bleeding?
