smog pump removal
Old 06-24-2008, 06:08 PM
vogs77
vogs77's Avatar
Default smog pump removal
I want to remove my smog pump, it is already disconnected from the headers, the pipe going down to the exause is just open, but it looks like tubes run to the back of the heads. What do you do to plug these off and can it be done while the engine is still in the car??? Looking at just putting an idler in place of the old pump. Lots of clutter in that area with the supercharger. Usless any way.
thanks
mat
vogs77 is offline
Old 06-24-2008, 06:12 PM
Dazzalad
Dazzalad's Avatar
Default RE: smog pump removal
There are threaded plugs made just for the back of the heads. You can order them from Summit. If you have someone local who rebuilds heads, they will likely have some as well. There are only $1.50
Dazzalad is offline
Old 06-24-2008, 06:19 PM
87foxgt
87foxgt's Avatar
like a $5000 dollar fine to haveNO smog pump!!!!!!!But they makeSmog pump eliminator. I see it all over ebay. and yes you can pull the smog pump out with out pulling the engine.
87foxgt is offline
Old 06-24-2008, 06:30 PM
camaroeater
camaroeater's Avatar
ORIGINAL: vogs77
thanks
mat
that pointless...just run a shorter belt.
camaroeater is offline
Old 06-24-2008, 06:32 PM
vogs77
vogs77's Avatar
No fine here. Classic plates in PA doesnot require and emissions test. Thanks for the warning though. I will try my local machine shop to see if they have plugs for the heads, can these plugs be installed while the engine is still in the car?? I could run a shorter belt, but that would not clean up the look of the engine area.
vogs77 is offline
Old 06-24-2008, 07:27 PM
reno27
reno27's Avatar
here you go http://rjminjectiontech.com/?p=9
reno27 is offline
Old 06-25-2008, 04:26 PM
MustangMan628
MustangMan628's Avatar
I Just removed my smog pump and catalytic converters/ mufflers in order to run true straight pipes out the side under the doors of my 89. Be sure to plug the vacuum lines as well as the heads. I wound up running a 74.7 inch 6 rib serpentine belt. that's with just the power steering pump, stock idler/tensioner pulley, underdrives on the alternator, crank and water pump. The car sounds like a v twin motorcycle when I get on it with just the 3 inch open pipes. IT'S LOUD!
MustangMan628 is offline
Old 06-25-2008, 04:46 PM
88fox50
88fox50's Avatar
ORIGINAL: vogs77
No fine here. Classic plates in PA doesnot require and emissions test. Thanks for the warning though. I will try my local machine shop to see if they have plugs for the heads, can these plugs be installed while the engine is still in the car?? <b> I could run a shorter belt, but that would not clean up the look of the engine area.</b>
what camaroeatr is saying is get rid of the smog pump and instead of putting an idler pulley back in its place. just get a shorter belt. and leave the space open....
88fox50 is offline
Old 06-25-2008, 06:01 PM
5pointslow91
5pointslow91's Avatar
wasnt there just a post about this the other day?
5pointslow91 is offline
Old 06-25-2008, 07:50 PM
vogs77
vogs77's Avatar
Sometimes I am a little stupid. 88fox50 I miss interpreted what camaroeater was saying. Good point and advice.F... the ilder just remove the pump completly and put it where it belongs in the trash.
thanks for all of the help
mat
vogs77 is offline
BOB ROME
07-26-2023 01:54 PM
jwog666
12-27-2021 08:09 PM
Dathan
10-05-2015 05:52 AM
Teddi
09-29-2015 12:24 PM
mrappe
09-26-2015 10:16 AM
Quick Reply: smog pump removal
