Harmonic Balancer removal/install
Old 06-25-2008, 12:51 PM
camaroeater
camaroeater's Avatar
Default Harmonic Balancer removal/install
Balancer will arrive today...I have already pulled fan shroud, blade, clutch, water pump and crank pulley. Im picking upthe puller and the 15/16's (24mm) socket to get the crank bolt out. Can I put the car in gear to remove crank bolt w/o the crank turning?
camaroeater is offline
Old 06-25-2008, 02:21 PM
drhoward
Penis Mod Erator
drhoward's Avatar
Default RE: Harmonic Balancer removal/install
I had to use a big pipe wrench on my old balancer to hold it as I undid the bolt.....make sure you take out the washer too[8D]
drhoward is online now
Old 06-25-2008, 03:39 PM
stanguy306
stanguy306's Avatar
Yeah and spray the bolt down with some lubricant in case its rusted....let it sit then hit with an impact....should do trick....and dont forget to remove washer...when using the puller...yes I have did that my first time...HAHA
stanguy306 is offline
Old 06-25-2008, 04:01 PM
94Yellow50
94Yellow50's Avatar
ORIGINAL: drhoward
exactly the way i did mine..didnt give a crap about the old one so i just looked for something that i could hold it with and the pipe wrench did the trick...sure the impact would be nicer...but we only had he big one at home so i had to comprimise...good luck
94Yellow50 is offline
Old 06-25-2008, 04:09 PM
camaroeater
So i remove crankbolt w/ washer, take washer off andthread bolt back in, then pull balancer?
Old 06-25-2008, 04:18 PM
94Yellow50
94Yellow50's Avatar
well ya the washers behind the bolt..so i gotta take the bolt all the way out..remove the washer...then thread the bolt enough of the way back in that it wont wiggle or anythingn mess up the threads...then used the pulled(if needed)...mine just pretty much slid off lol...
Old 06-25-2008, 08:17 PM
aode08
aode08's Avatar
ORIGINAL: camaroeater
should not of touched the water pump unless bad.
the easy way, put a socket on a breaker bar (24mm) against frame(on the loosen setting), bump the starter, bam, bolt loose.
Take 2-3 pulley bolts toattach the puller to dampner, then the long rod screw, that goes into the puller topull the balancer from crank.
aode08 is offline
Old 06-26-2008, 09:37 AM
camaroeater
Got the new Ford balancer installed...car is running great now. I think the balancer could of been on its way out over a year ago when I got thecar. I always had minimial vibration at 3000rpms+, now it doen't vibrate at all. It even came w/ a new pointer that made it way easier to read timing marks.
mtgldr
02-03-2024 09:00 PM
jessicarabbit
09-25-2015 12:41 PM
LivingInThePast
09-16-2015 12:20 PM
tj@steeda
Steeda Autosports
09-08-2015 11:50 AM
Urambo Tauro
08-27-2015 10:53 AM
Quick Reply: Harmonic Balancer removal/install
