1966 Mustang (200 CID) Ignition Timing?
Old 07-02-2008, 03:32 PM
bandit1
bandit1's Avatar
Default 1966 Mustang (200 CID) Ignition Timing?
I have a 1966 Mustang (Convertible/Straight-6/200 CID/Autolite 1100 Carburetor/C-4 Automatic Transmission). I have replaced the spark plugs, spark plug wires, points/condenser/rotor, and set the points gap. My next step is to set the ignition timing. I would like to know what the correct timing is. I've looked online and have seen 6 degrees, but I've also seen 12 degrees. The current timing appears to be set at 8 degrees. Also, what is the best method to set the timing? I've heard of static timing and dynamic timing. Thank you.[/align]
bandit1 is offline
Old 07-02-2008, 05:18 PM
.boB
.boB's Avatar
Default RE: 1966 Mustang (200 CID) Ignition Timing?
To set the timing on an old or modified engine is with a vacuum gauge. Hooke the gauge up directly to manifold vacuum. Set the timing where the vacuum is highest.
.boB is offline
Old 07-02-2008, 05:29 PM
1slow67
ROTM Moderator
1slow67's Avatar
Take off the vaccum advacnce on the carb, then get a timing light. I think my 200 is set at 13. Loosen the distributor just enough to where you can move it. Then move it while looking at the timing to change. Once set properly tighten and start changing the idle and air to fuel mixture on the carb.
1slow67 is offline
Old 07-03-2008, 10:12 AM
falconfixer
falconfixer's Avatar
Static is as described above (no advance)
Dynamic is a test of the advance system - you should see the timing advance as the engine RPM increases.
More timing advance is better. Run the higher number if it doesn't knock or is hard to start when hot.
falconfixer is offline
Old 07-03-2008, 10:14 AM
falconfixer
ORIGINAL: BA Mustang
(Plug the vacuum line with a golf tee to hold a better idle)
djbigskrilla
09-20-2022 01:04 AM
KEM Motorworks
08-14-2015 10:13 PM
daytooday
08-11-2015 09:22 AM
Darrens07GT
08-10-2015 03:59 PM
Quick Reply: 1966 Mustang (200 CID) Ignition Timing?
