FOLVO SWAP
Old 07-30-2008, 11:53 PM
turbo87mustang
turbo87mustang's Avatar
Default FOLVO SWAP
what all do i need to do the volvo head swap? very much considering doing since we just got the first dohc i seen. and as far as i mean as what i need, intake? fuel rail? exhaust? fuel injectors? timing belt? crank pulley? and do i have to change to DIS or is TFI fine?
turbo87mustang is offline
Old 07-30-2008, 11:54 PM
turbo87mustang
Default RE: FOLVO SWAP
not TFI, but distributor (whatever its called) or DIS
Old 07-31-2008, 02:35 AM
KFC
KFC's Avatar
it requires some fab work, it's not a bolt on mod
Tap and thread the rear oil return passage of the block and install a plug.
Seal bottom water outlet
Mod middle combustion chambers to better match the head gasket
Match water passages with the Ford gasket
Tap the head for an external oil feed
Weld a block of aluminum to the back of the Volvo head to run an external oil supply line
you'll find several writeups with a quick google search
KFC is offline
Old 07-31-2008, 02:38 AM
al_ngl
al_ngl's Avatar
Which volvo is the head off of?
al_ngl is offline
Old 07-31-2008, 05:08 AM
spdrcer34
spdrcer34's Avatar
b234f
Found in Early 90's Volvo 740's I believe
Ryan
spdrcer34 is offline
Old 07-31-2008, 08:29 AM
turbo87mustang
early 90s 740s lol .. like he said .. wow, nevermind .. thats too much fabrications lol .. ill do that later when i get a spare block and rebuild it lol im kinda like budget wise .. so far i spent 500, including body parts, and i plan only to spend 3000
Old 07-31-2008, 06:38 PM
spdrcer34
spdrcer34's Avatar
You can find the head on eBay. Type in 'b234f' in the search, and you'll find one, as well as the parts needed to make the swap.
Ryan
Old 07-31-2008, 11:12 PM
hellion_79
hellion_79's Avatar
Basically everything the the volvo head came with as far as fuel rail and injectors, possibly a different timing belt cause it will have to be larger.
I also know that you will need to make a custom intake. i havent looked into this swap much but this is what I have heard. I would love to see someone in this forum to actually do the head swap, all I have seen is turbo swaps here, nothing with a volvo head but just talk about it and never go thru with it. Maybe be the first to do it on this forum and take lots of pics of the progress.
hellion_79 is offline
Old 08-01-2008, 12:27 AM
turbo87mustang
i want to do it because u know dohc can do better cams and stuff with it and just looks cleaner if u ask me .. im still trying to find all steps into doing it .. but so far sounds like alot of fabrications
Old 08-01-2008, 11:35 AM
sleeper_inc
sleeper_inc's Avatar
****!!!!!!!!!!!!!! I had a whole bunch of links for you but it wouldn't let me post
Go to turboford.net and go to tech bored (left colum) then click search (top right of page) and type in folvo conversion
sleeper_inc is offline
GimpyHSHS
19
12-19-2023 01:12 PM
Bokeo
10-10-2015 08:28 PM
Matt's 95 Stang
10-05-2015 07:16 AM
guitarman376
09-30-2015 05:54 PM
UrS4
09-30-2015 10:13 AM
Quick Reply: FOLVO SWAP
