Sponsored by: DashLynx
Can't siphon gas tank.
Old 08-04-2008, 09:06 PM
Wildwisc
Wildwisc's Avatar
Default Can't siphon gas tank.
I have a '95 3.8L that I just finished putting a new engine in. It's all ready to go, all I need to do is drain the old gas out of the tank. (It's been sitting for about a year and a half with a 3/4 full tank.) I've tried siphoning the gas out but I can't get the hose down into the tank. It goes in about a foot and a half to two feet and then won't go any further. It feels like it is hitting something anf I can't get past it.
What do I need to do to get the old gas out of this tank?
Thanks in advance.
Wildwisc is offline
Old 08-04-2008, 09:47 PM
psyviperx
psyviperx's Avatar
Default RE: Can't siphon gas tank.
drill a tap in the bottom. drain it then plug the hole. dont worry the gas will dissipate the heat from drilling. it wont explode. might ruin the drill when the gas hits it though.
really. im not sure how the stangs anti siphon thing works. you might want to try to get the smallest tubing you can find.
psyviperx is offline
Old 08-04-2008, 10:00 PM
LilRoush
LilRoush's Avatar
There is a screen in place to prevent it. Lower the fuel cell down, pop the top and suck it out that way.
LilRoush is offline
Old 08-04-2008, 11:35 PM
ExtrmZ
ExtrmZ's Avatar
i like the idea of drilling a hole to drain it out.. but then you have a hole in your tank... yeah there is a screen in the way so you cant siphon out the gas..
ExtrmZ is offline
Old 08-05-2008, 06:21 AM
ewgoetz
ewgoetz's Avatar
1 of 2 ways.
1. disconnect the lines going to the fuel rail and aim them into a gas can or what ever container you were gonna drain it into. than jump the fuel pump relay.
2. get a external fuel pump to suck the fuel out the same fuel lines from the rails.
I would of hooked up a fuel pressure guage with the old motor and used the guage drain offto drain the fuel and let the motor run till the tank was empty, motor would of shut off as soon as there was no gas in the tank.
Ps bad idea about using a drill unless it is a air drill....Electric drill+Sparks from drill motor+fuel=Fire
Hammer and Nail would be safer.
ewgoetz is offline
Old 08-05-2008, 07:54 AM
Chopper
Chopper's Avatar
Who in the H311 would drill a hole in their gas tank?????
If the car will run just fill the tank with 91 octane and drive the thing until you can add another 1/4 tank and so on.
Chopper is offline
Old 08-05-2008, 09:51 AM
ewgoetz
ewgoetz's Avatar
A crackhead would drill there tank.......[sm=happybounce.gif]
ewgoetz is offline
4cylinderplus2
10-09-2020 07:45 PM
Sixer4Life
10-12-2015 04:26 AM
b8checker
10-08-2015 12:55 PM
Matt's 95 Stang
10-05-2015 07:16 AM
mrappe
09-26-2015 10:16 AM
Quick Reply: Can't siphon gas tank.
