Volvo Head Swap
Old 08-06-2008, 11:39 PM
sleeper_inc
sleeper_inc's Avatar
Default Volvo Head Swap
For anyone who wants to try the volvo head swap on the 2.3 LIMA engine, Here are some helpful links for you
Car with the proper cylinder head
89-90 Volvo 740 GLE
91 Volvo 940 GLE (Canadian)
Engine # B234F
http://www.turboford.net/ubb/ultimat...c;f=3;t=025541
http://www.turboford.net/cgi-bin/ult...c;f=2;t=041747
http://www.turboford.net/ubb/ultimat...c;f=3;t=025603
http://www.turboford.net/cgi-bin/ult...c;f=3;t=022395
http://www.turboford.net/cgi-bin/ult...c;f=2;t=039858
http://www.turboford.net/cgi-bin/ult...;f=20;t=003080
http://www.turboford.net/ubb/ultimat...c;f=8;t=000021
http://www.turboford.net/ubb/ultimat...c;f=2;t=047427
http://www.turboford.net/cgi-bin/ult...;f=20;t=003170
http://autos.groups.yahoo.com/group/2300-16V/
http://www.merkurtech.com/merkurtech...es/item045.php
There is also another one at
geocities. c o m /_nitro_/volvoswap/volvoswap
(remove the spaces in the .com)
Your welcome
sleeper_inc is offline
Old 08-06-2008, 11:45 PM
KFC
KFC's Avatar
Default RE: Volvo Head Swap
fgtj?
You been painting without proper ventilation or playing with some starter fluid?[sm=alcoholic.gif]
I've read about the swap, but it's more work that I'm interested in doing. I have access toa machine shop if I need it so maybe one day I'll reconsider it.
KFC is offline
Old 08-07-2008, 12:03 AM
sleeper_inc
It's fixed now, didn't like the geocities site[&:]
Old 08-09-2008, 08:03 PM
omegagodly
omegagodly's Avatar
with these heads what kind of performane increase can be expected?
omegagodly is offline
Old 08-09-2008, 08:21 PM
sleeper_inc
It really depends on your set-up.
No one has solid numbers on all stock just the head.
But from all the info Ive gathered, you've got a **** load better air flow which makes it better outside boost I would think
Old 08-09-2008, 08:48 PM
omegagodly
omegagodly's Avatar
so this head would be compatible with the t4 engine?
Old 08-09-2008, 09:08 PM
sleeper_inc
ORIGINAL: omegagodly
uhh... what? speak engish, not engine to me
Old 08-10-2008, 11:18 AM
omegagodly
omegagodly's Avatar
lol sorry. so this head is compatible with the turbo engine in the 1988 thunderbird i have? i can use these on that engine correct? what is the lima engine?
Old 08-10-2008, 06:11 PM
sleeper_inc
The LIMA engine is the 2.3 ford turbo engine, the B234T is the engine in the volvo.
The head will fit but only with mods to either the cylinder head or the block.
they share the bolt placment, but the volvo head is a little to short so a aluminum block has to be welded on and custom pistons have to be made.
Im missing most of it, but thats why there are links....
Old 08-10-2008, 08:12 PM
Jugador
Jugador's Avatar
i think it would be a lot easier to use more boost and port the stock or a dp head than messing with that complicated of a swap.
Jugador is offline
Quick Reply: Volvo Head Swap
