P0301 Error Code 2002 Mustang 3.8L V6
Old 08-07-2008, 10:32 PM
bkey
bkey's Avatar
Default P0301 Error Code 2002 Mustang 3.8L V6
We have a 2002 3.8L V6 mustang that is very sluggish when taking off and seems to miss will cruising at a constant speed. The check engine light came and I had AutoZone tell me the code.
It is a P0301 which is cylinder 1 misfire. They told me the OEM cross number was P0316 which is the crank sensor failure.
I replaced the crank sensor and nothing changed...
Any help would greatly be appreciated.
Thanks
bkey is offline
Old 08-07-2008, 10:43 PM
RoBDoG
RoBDoG's Avatar
Default RE: P0301 Error Code 2002 Mustang 3.8L V6
have you looked at your spark plugs?
RoBDoG is offline
Old 08-07-2008, 10:46 PM
Richbrad08
Richbrad08's Avatar
check your wires sometimes the egr pipe can burn a hole in 1 or your headers
Richbrad08 is offline
Old 08-07-2008, 10:47 PM
bkey
bkey's Avatar
Thanks for the reply.
Not yet but after reading all the threads I guess will do the following:
Change fuel filter
Change plugs
Change plug wires
Change coil packs
Change air filter
Hope all this works! Any other ideas, please let me know.
Thanks,
bkey is offline
Old 08-08-2008, 07:39 AM
troy81
troy81's Avatar
thant youll def get it. its probably coil packs, 8x,xxx miles? thats when mine went in my 02
troy81 is offline
01blackgtconv
08-14-2015 04:50 PM
daytooday
08-11-2015 09:22 AM
Danwiel
08-11-2015 06:49 AM
01blackgtconv
08-10-2015 01:25 PM
UINZWAY
S197 Shelby Section
08-05-2015 10:34 PM
Quick Reply: P0301 Error Code 2002 Mustang 3.8L V6
