Hot Rod Cam Installation Guide
#223
Follow the write up and you will be fine.
#224
Most have already seen this Ford tech video of a cam change, but i've added it to the writeup for future DIY cam changers.
reading the procedure is a great start and this video may help answer some additional questions.
summer is coming fast, let's get those cams in!
mms://multimedia.ford.com/seopts/Tech17_250k.wmv
#225
Just to clarify and be sure.
When installing cams such as thumprs or hot rod cams. Do you need to adjust anything on the rocker arms to be sure they arent loose or to tight. Or do the cams all just drop in and no adjustments need to be made?
Ive seen adjustable lash pins or something and just wanna make sure i know
#226
hi there Lem-06, nothing needs to be done with the cam followers
or lash adjusters.....
thumpers may require cam phaser limiters or lockouts depending
on which stage you go with, so check on that before deciding
which cam to go with.
#229
Thanks
Thanks everyone. The information you provided was extremely helpful and useful. My son and I installed the new cams and timing chains yesterday. Everything went very smoothly. I even manually rotated the crank several rotations after install to make sure everything operated correctly.
#230
S197 11-14
Hello guys I have genral question I have 2012 gt auto lol headers long tubes x borla with jlt in take as well as aluminum driveshaft 1.5 lowers 305s in rear 255 in front nitto with a tuned best duno run was 415 to the wheels not bad for a auto my question is I’m thinking about cams with cam kit and I stall trying to spend max of 5k what are best cams to get I want something that sounds really aggressive also has good power gains thank you
jkm1987
06-11-2008 04:03 PM
90Mustangfan
10-06-2005 11:17 PM
