Where to buy a 289/302 Dependable Long Block Engine
Old 09-07-2008, 02:14 PM
ok_ee
ok_ee's Avatar
Default Where to buy a 289/302 Dependable Long Block Engine
Hello,
I have a 1966 Mustang that currently has a stock 289 engine that needs to be rebuilt. I have estimates of getting it rebuilt and it seems to be cheaper to buy a newly rebuilt stock long block engine. Some place on the web sell them for $1,100 and give you a great warranty. I was wondering if anyone has purchased an engine and knows where the best place to buy one is. I want a dependable engine, not look for anything extravagant. I prefer not to buy an engine from a private seller because the one I have in my mustang now is my second engine that the guy i bought it from claimed it was a good engine (lost $500, ohhh well!). I appreciate all suggestions!
ok_ee is offline
Old 09-08-2008, 02:26 PM
FasterCat
FasterCat's Avatar
Default Good Reliable Engine
Blueprint 5.0 Roller Motor from Jegs (much more power than stock 289) = $1600
.... and if you want to have a little more fun ($800 for everything you'd need),
throw in a Comp Cams 281HR
Or do like I did and find a good/reputable local place and get a 400 HP long block
built for "close to" the same amount ...
Download the Comp Cams calculator software ... it's fun to look at the possibilities !
FasterCat is offline
Old 09-08-2008, 03:59 PM
ok_ee
ok_ee's Avatar
Great! Thanks for the input!
ok_ee is offline
Old 09-08-2008, 04:10 PM
rmodel65
Yukon Cornelius
rmodel65's Avatar
might want ot pick up a 5.0 late model mag from the book store, normally they have 331 and 347 long blocks for just a couple dollars more
just my 2 cents
347>302
rmodel65 is offline
Old 09-08-2008, 04:29 PM
cmanf
cmanf's Avatar
jasper engines is a good source for a plain longblock.
cmanf is offline
Old 09-08-2008, 06:28 PM
ok_ee
ok_ee's Avatar
Default Power Source Engines
Found a place,
http://www.psengines.com/
Power Source. They sell rebuilt 302 engines for around $1,200! They have a 3 year 100K mile warranty and will even cover labor if anything goes bad.
ok_ee is offline
Old 09-08-2008, 07:50 PM
cprstreetmachines
cprstreetmachines's Avatar
yep, so is blueprint. But you can't beat Jaspers warranty.3 yr/100,000mi. they break it for you, check the stuff before you get it. Comes with a new oil pan.
cprstreetmachines is offline
Old 09-08-2008, 09:28 PM
JordanSepto
JordanSepto's Avatar
I got mine from Rhino, delivered to my door for around 1100.00 IIRC. They even date coded it for me so they must have a huge inventory of cores. Same warranty as Jegs and the others. Bought it 3 years ago and its still running perfect. Hope this helps!
Jay
JordanSepto is offline
Old 09-08-2008, 09:32 PM
my77stang
my77stang's Avatar
having a local reputable shop rebuild your 289 is such a better route to go
my77stang is offline
Old 09-08-2008, 09:37 PM
htwheelz67
htwheelz67's Avatar
except for originality, a late model 5.0 has too many advantages over rebuilding a 289.
htwheelz67 is offline
Quick Reply: Where to buy a 289/302 Dependable Long Block Engine
