Old 10-08-2015, 01:14 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Interior Guides
Print Wikipost
proper way to reset or clear the computer?
Old 10-04-2008, 08:54 PM
mustanglouie
mustanglouie's Avatar
Default proper way to reset or clear the computer?
I was wondering what is the proper way for completely resetting the computers in our cars?
I have heard a couple different theories. One is to just take off the neg. terminal and let the car sit for about 30 mins and then put it back on. But does this completely wipe out the memory of the computer? I have also heard that you could take the pos. and neg. terminals off the battery and touch them together for a few mins and that would completely wipe out the memory of the computer. So what is the correct way to completely clear the entire memory on our cars without hurting them?
mustanglouie is offline
Old 10-04-2008, 09:42 PM
hammeron
hammeron's Avatar
it seems to me, that you need the:
Rotunda Worldwide Diagnostic System (WDS), Vehicle Communication Module (VCM) with
appropriate adapters or equivalent diagnostic tool.
here's a copy and paste from the service manual:
Resetting The Keep Alive Memory (KAM)
Description
Resetting the KAM returns the powertrain control module (PCM) memory to its default setting. Adaptive learning contents such as idle speed, refueling event, and fuel trim are included. Clear the continuous diagnostic trouble codes (DTCs) in the PCM and reset the emission monitors information, is part of a KAM reset. Refer to Clear the Continuous Diagnostic Trouble Codes (DTCs) and Reset the Emission Monitors Information in the Powertrain Control Module (PCM) in this section. Both can be useful in post-repair testing.
After the KAM has been reset, the vehicle may exhibit certain driveability concerns. It is necessary to drive the vehicle to allow the PCM to learn the values for optimum driveability and performance.
This function may not be supported by all diagnostic tools. Refer to the diagnostic tool manufacturer's instruction manual.
If an error message is received or the diagnostic tool does not support this function, disconnecting the battery ground cable for a minimum of 5 minutes may be used as an alternative procedure.
hammeron is offline
Old 10-04-2008, 10:03 PM
volcomchester18
volcomchester18's Avatar
^^ or simply disconnect the battery for a few minutes. It really wont damage anything. If they got damaged that way, ford would have to replace ecu's daily, since many people drain their batteries and need a jump start.
volcomchester18 is offline
Old 10-05-2008, 12:01 AM
Cloewe06
Cloewe06's Avatar
Default RESET
Just take off positive side for 10-15 minutes.
Don't touch them together
cloewe
Cloewe06 is offline
Old 10-05-2008, 03:31 AM
volcomchester18
cloewe
even though, it doesnt really matter. Usually its better to remove the negative instead of the positive, causes less sparking but either way it works.
Old 10-08-2008, 03:02 PM
russje
russje's Avatar
Default Clearing computer
After you disconnect either of the battery cables, step on the brake pedal for a few seconds. That will make sure you pull all the power out of the system. Also it is better to remove the negative cable to avoid sparking.
I've never heard of touching the positive and negative terminal together.
Jeff
russje is offline
Old 10-08-2008, 04:20 PM
Nuke
Nuke's Avatar
I believe the sparking referred to above has to do with removal and reconnection of either terminal to the battery. When I disconnect the battery, I use the negative and there's been no sparking. But that's how I've always done it...
Surprisingly, the only thing I've ever had to reset was the clock. Even my radio stations all came back.
Nuke is offline
Old 10-08-2008, 04:36 PM
AmericanMuscle4.6GT
AmericanMuscle4.6GT's Avatar
+1. that was very ftw.
AmericanMuscle4.6GT is offline
Old 10-08-2008, 04:58 PM
bolivianpimp
bolivianpimp's Avatar
I know this sounds stupid... but what does ftw mean?
bolivianpimp is offline
Old 10-08-2008, 05:04 PM
birdoffire7
birdoffire7's Avatar
FTW = For The Win. I agree, I've also always simply unconnected the neg battery cable and let the car sit for a few minutes. I've already done it on my current car and worked fine, didn't hurt anything.
birdoffire7 is offline
Quick Reply: proper way to reset or clear the computer?
