Does anyone know the size of a stock throttle body
Old 11-11-2008, 11:21 AM
foru2nv4
foru2nv4's Avatar
Default Does anyone know the size of a stock throttle body
Does anyone know the size of a stock throttle body on a 2003 Mustang GT 4.6 litre? I am curious of the size then I want to upgrade to a larger bbk throttle body because I have a twin screw supercharger on the car right now running the stock throttle body. Any suggestion on the size I should upgrade to would be also appreciated.
Thanks
foru2nv4 is offline
Old 11-11-2008, 11:37 AM
cliffyk
TECH SAVANT
cliffyk's Avatar
Thanks
65 mm, upgrade to a 75 or BBKs new 78 mm TB/plenum combination--but don't expect a gigantic difference. It will be quite noticable but not huge...
cliffyk is offline
Old 11-11-2008, 11:49 AM
foru2nv4
foru2nv4's Avatar
Default Dont need the plenum
I don't need the plenum because I have a twin screw supercharger that sits ontop of the engine with a stock throttl body attached to the arm of the saleen series IV supercharger. So you say the stock size of a 2003 mustang gt throttle body is 65mm? I appreciate that I think a 75mm on this supercharger will be a big increase for air to the supercharger?
2003 Mustang GT
Saleen supercharger series IV, 4.10s, slp loudmouth exhaust, 30lb fuel injectors, saleen pcm programmed, mass air to 30lb injectors, cold air kit, 160 degree thermostat, 2.91 pulley for supercharger, smaller belt 112.5"
foru2nv4 is offline
Old 11-11-2008, 05:17 PM
devore86
devore86's Avatar
Do u think the 78mm would be too much for my car, ive been lookin at it, its a good deal.........just not sure
devore86 is offline
Old 11-11-2008, 05:23 PM
cliffyk
TECH SAVANT
cliffyk's Avatar
It won't hurt anything to any great degree (a slight decrease in charge velocity at WOT, that will hurt a bit at higher RPMs when the 2V heads don't breath so well), however as long as you run n/a it also won't do anything that a 70 mm TB (and aftermarket plenum) couldn't...
cliffyk is offline
Old 11-11-2008, 05:26 PM
SilvrStang
SilvrStang's Avatar
Dude 75 or 78 mm is an overkill . Yes it will hurt the performance. Go with a 70mm its more then enough on an N/A 2 valve.
SilvrStang is offline
devore86
devore86's Avatar
kinda what i figured, its always good to have a 2nd opinion though........thnx
devore86 is offline
Old 11-11-2008, 08:04 PM
boduke0220
boduke0220's Avatar
he is supercharged
boduke0220 is offline
Old 11-11-2008, 08:17 PM
SilvrStang
SilvrStang's Avatar
Havent read that. N/A 70 MM
75MM would do the job for your twin screw setup.
Old 11-11-2008, 08:40 PM
248spider
248spider's Avatar
after reading your comments that u posted about not going with a 75mm tb, not to be a smart *** but i was looking at your bolt ons and your hp.compaired to what i put on i gained more rwhp from that.i have c&l plenum,bbk75mm tb,bbk cai,and tune by donnie walsh jr.i got 255 rwhp 300torque this was also at 92 degree temps w 30% humidity.i should also add that i have a cheapo pace setter h pipe,and 100,000 stock mufflers.
248spider is offline
Quick Reply: Does anyone know the size of a stock throttle body
