Water Leak - Passenger Side
Old 11-16-2008, 07:50 PM
bull49
bull49's Avatar
Question Water Leak - Passenger Side
Twice now after a heavy rain, we have had standing water on passenger side floor board. The first time I went to dealer, they checked a/c drain and said everything was ok. Does anyone have any suggestion what may be causing this? Again, we have only noticed after heavy rain. This last time the water was high enough to run into rear floor area. This is a 2006 Mustang Convertible. There is no indication of any leaks coming from windows or top.
bull49
bull49 is offline
Old 11-16-2008, 07:56 PM
americaniron
americaniron's Avatar
It's a common problem with the earlier cars of this model. Make them fix it under TSB 07-14-6. I had it too, and it was fixed under this TSB.
americaniron is offline
Old 11-16-2008, 08:01 PM
Nuke
Nuke's Avatar
+1
A little searching and you'll find all the info on this you want to know. Rather common and discussed a lot.
Nuke is offline
Old 11-16-2008, 09:46 PM
HT
HT's Avatar
I know it's a common problem but it is funny how you went to the dealership and told them that there was standing water in your passenger floorboard and they could still tell you that everything was fine. I think standing water is usually a sign of a problem...
Stupid dealerships...
HT is offline
Old 11-16-2008, 10:21 PM
doode
doode's Avatar
bull49
its stories like this that make me so goddamn happy that ford is going under
built **** cars, give the shaft to customers when things go wrong
doode is offline
Old 11-16-2008, 10:25 PM
Texotic
Texotic's Avatar
yeah, lets all celebrate the collapse of the economy and degradation of competition in the car market. [/sarcasm]
Texotic is offline
Old 11-18-2008, 07:03 PM
xtremesaleen
xtremesaleen's Avatar
YAY a TSB on the leak. After the last several days of rain I can barely drive my car it smells so bad. I thought i had smelled mildew when it rained before but now its really overwhelming but i couldnt find a puddle, just a stench originating from the passenger side.
xtremesaleen is offline
Old 11-18-2008, 07:44 PM
aircare84
aircare84's Avatar
Like was mentioned earlier, it has been a common problem & there is alot of discussion on the subject.
Most of the leaks have been traced to plugged drains under the cowl panel, then the water comes in through the cabin air filter.
Mine was a leak only when parked & I traced it down to a poorly sealed grommet behind the pass side inner fenderwell. Fixed mine about a year ago & haven't had any issues since.
The cowl leak appears to be the most common.
Pics attached.
Attached Thumbnails Water Leak - Passenger Side-dsc03746a.jpg   Water Leak - Passenger Side-dsc03747a.jpg
aircare84 is offline
Old 11-18-2008, 08:03 PM
Cobrakev
Cobrakev's Avatar
Pull the cover off where the Cabin Air Filter is. There is a drain under the cover that gets clogged up with leaves and such. You will also need a new filter. When you look at the filter, you will see how high the water really got.
Cobrakev is offline
Old 06-06-2011, 12:12 PM
mudhens84
mudhens84's Avatar
bull49
On the firewall there are 2 black rubber bladders. There are the srains. Stcik your index finger up iside of them and clean out the debris. Do this on a monthly basis and you will be all set.
Mudhens84
mudhens84 is offline
Quick Reply: Water Leak - Passenger Side
