a9l vs a9m
Old 11-19-2008, 09:59 PM
dv3
dv3's Avatar
Default a9l vs a9m
whats the difference?
dv3 is offline
Old 11-19-2008, 10:26 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
fuel and spark tables are a tad more aggresive I believe on the a9l....I believe the a9l is the 5 spd ecm and the other is the auto??
mjr46 is offline
Old 11-19-2008, 11:15 PM
dv3
dv3's Avatar
i have a9m in 5sd lx vert ...theres a sticker (a9m) in the door jam and on the ecm
dv3 is offline
Old 11-20-2008, 12:01 PM
Timspony
SVT Section Moderator
Timspony's Avatar
Maybe the car had a T-5 transplant....A9L came stock with the 5 speeds, A9M with the AOD's....A9M will work fine with a T-5, it just controled yhe shift points of the AOD...Pull the computer out and see which one you have (disconnect the battery first )
Timspony is offline
Old 11-20-2008, 01:33 PM
dudeboy
dudeboy's Avatar
I'll look a little more for an A9M.bin file, then we can look at what the real differences are.
It sounds like the A9M may be pretty similar to the A9P though?
Anyone compared .bins?
dudeboy is offline
Old 11-20-2008, 01:34 PM
dudeboy
dudeboy's Avatar
lol,
I just found one....
I won't be home until late tonight, but I'll take a look by tomorrow...
EDIT:
just in case some one else would like to do a comparison in the mean time...
http://www.eecanalyzer.net/downloads....php?dir=/GUFB
dudeboy is offline
Old 11-20-2008, 03:00 PM
Joel5.0
Joel5.0's Avatar
Check the camparison between the A9L, A9P and X3Z with http://www.eecanalyzer.net/tech/docs/EEC_Compare.xls
Joel5.0 is offline
Old 11-20-2008, 04:30 PM
dv3
dv3's Avatar
i cant be sure ...i tryed to look at the old carfax and tried decoding the vin but niether was able to confirm that it was a stock 5spd
but i did just completely disassemble the car and it looked stock ...considering everything else was almost completely stock i would find it hard to believe that someone would have went through all the work to change it to a 5 spd and done nothing else ...and i also think that i would have noticed some where along the line that it had originally been an auto but not sure
the computer says a9m though ...plug was gray if that tells you anything
dv3 is offline
Old 11-20-2008, 04:37 PM
dv3
dv3's Avatar
Originally Posted by dudeboy
lol,
EDIT:
thanks
ill be waiting
interesting but theres no a9m in there
i think i finally stumped everyone ...is this possible???
dv3 is offline
Old 11-20-2008, 08:36 PM
SICNINETYCOUPE
SICNINETYCOUPE's Avatar
the AOD is not an electronicaly controlled trans the AOD-E is and those use the EEC-V. An a9m will work with a manual trans it does however have more initial timing advance so watch out for knock and minor drivability issues like surging and bucking in some cases depending on your mod list.
SICNINETYCOUPE is offline
Quick Reply: a9l vs a9m
