Car won't start... no spark
Old 11-28-2008, 09:30 PM
sipynsyrup
sipynsyrup's Avatar
Default Car won't start... no spark
NO spark at coil..
The dist rotor spins fine
New plugs/wires/rotor/cap
replaced coil
With ignition "on" there is only 2V at every injector red wire and 2V on red wire on MAF
Isn't it supposed to be 12V?
Checked fuses under hood and all were good
I bought a new ignition control module but haven't put it on yet.
What should I DO!!!??? Im stumped
sipynsyrup is offline
Old 11-28-2008, 09:44 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
put the tfi module on and see if that corrects if not it may have a bad stator in the distributor which generates what is known as the PIP signal which is sent to the ecm where it takes all info provided from input sensors to create a signal known as SPOUT = SPARK OUTPUT....the spout signifies engine operation condition and is sent back to the tfi module for comparison with the PIP signal, the tfi then uses both of those signals to fire the ignition coil at the proper timing intervals...so if you have power at the coil but no spark output from it, either the PIP signal from stator is missing or a bad tfi that doesn't interpret the SPOUT from ecm..........that's to say all secondary ignition components are in proper working order....ie, cap rotor and wires ect ect
mjr46 is offline
Old 11-28-2008, 09:55 PM
redpony88
redpony88's Avatar
it could also be the coil itself, i know i've run into that before. where we got no spark so we threw a tfi at it, for some reason my friend was convinced it wasnt getting fuel even though it reeked of it...... so he went and got a new pump, etc etc anyway he thew all these parts at it but... it turned out JUST to be the coil. and you can pick up a msd one for like 40-45 bucks at the parts store
redpony88 is offline
Old 11-28-2008, 10:05 PM
sipynsyrup
sipynsyrup's Avatar
Already put a new coil on it
The coil red wire is only getting .2V with the ignition on
ALSO, I can crank it for a long time and still smell no fuel....
Old 11-28-2008, 10:13 PM
mjr46
mjr46's Avatar
http://sbftech.com/index.php/topic,588.0.html
mjr46 is offline
Old 11-28-2008, 10:25 PM
sipynsyrup
sipynsyrup's Avatar
well figured something else out:
FUel pump not kicking on.
Fan isn't turning on(supposed to turn on when key forward)
No spark
Old 11-28-2008, 10:44 PM
sipynsyrup
sipynsyrup's Avatar
I tried hotwiring the coil off the red wire. AS soon as I put power to it my fan turned on. I tried cranking and the rpm meter jumped up and just got stuck.. still no fuel though. I think it would crank but the fuel pump isn't even priming.
Old 11-28-2008, 10:59 PM
sipynsyrup
sipynsyrup's Avatar
Where is the ECM located? Pretty sure its a bad ecm
Old 10-21-2011, 03:17 PM
mustanggtman302ci
mustanggtman302ci's Avatar
No spark
I had a similar issue but it was because my wires to my sylinoid weren't hooked up correctly. Hope this helps. All I did was looked at another friends stang as a reference when I was troubleshooting. it was obvious my wires were wrong.
mustanggtman302ci is offline
overnight89
08-22-2015 09:02 PM
KEM Motorworks
08-14-2015 10:13 PM
92 5.0stang
08-13-2015 06:46 AM
Milan Dragway
08-12-2015 03:43 PM
Quick Reply: Car won't start... no spark
