How do i remove the entire windshield wiper arm?
Old 11-30-2008, 09:01 PM
DreamBMC
DreamBMC's Avatar
Default How do i remove the entire windshield wiper arm?
How do I remove the entire windshield wiper arm, I am going to make a custom delete for $3.00 but dont know how to get it off. Help?
DreamBMC is offline
Old 11-30-2008, 09:04 PM
mustangman281
mustangman281's Avatar
Pull out on the C clip and lift the wiper arm off.
mustangman281 is offline
Old 11-30-2008, 09:06 PM
Novanutcase
Novanutcase's Avatar
At the base of the wiper there is a little retaining clip arm sticking out. You have to pull it out and the arm will come off. Sometimes since they've been there for a while you have to push down on the base then pull the RCA out.
John
Novanutcase is offline
Old 11-30-2008, 09:07 PM
DreamBMC
DreamBMC's Avatar
I mean windshield wiper might be different but I do have a little thing I can pull out, its slides back and forth easily. I pulled it out and tried pulling up but wouldnt budge.
DreamBMC is offline
Old 11-30-2008, 11:12 PM
karrarararararar
karrarararararar's Avatar
sorry if this questions seems confusing but, are you trying to pull it up with it extended a crossed the windshield like it normally sits or do you have it pointing up and away from the windshield?
karrarararararar is offline
Old 11-30-2008, 11:40 PM
DreamBMC
DreamBMC's Avatar
I tried sliding the little thing out and pulling up with the windshield wiper arm standing up, is that wrong?
DreamBMC is offline
Old 12-01-2008, 01:24 AM
Novanutcase
That's fine! Either way. Like I said, over time it gets stuck on there so you may need to wiggle it or push it down then back up to get all the crud and corrosion that may have accumulated.
John
Old 12-01-2008, 01:30 AM
karrarararararar
it should come off the way you're doing it like novanutcase said it's probably just stuck. try spraying it with wd40 or whatever you have
Old 12-01-2008, 07:31 AM
Eagle2000GT
Eagle2000GT's Avatar
I had trouble getting mine off. Lift the windshield wiper arm up so that it stays off the window by itself. If you look closely you can see a vertical tab that is connected to the lever you pull out. Take a small screwdriver and gently pry that tab out as you pull on the lever. Holding the tab out lower the wiper arm back down so that the tension holds the tab out.
Eagle2000GT is offline
jwog666
12-27-2021 08:09 PM
Dathan
10-05-2015 05:52 AM
UrS4
10-03-2015 06:23 AM
jrrhd73must
10-02-2015 09:17 PM
UrS4
09-30-2015 10:13 AM
Quick Reply: How do i remove the entire windshield wiper arm?
