speaker wires...which is postive/negative?
Old 12-26-2008, 11:14 AM
camaroeater
camaroeater's Avatar
Default speaker wires...which is postive/negative?
im trying to figure out which rear speaker wire is positive and negative, both wires have stripes. I've searched and searched and havn't found ****.
camaroeater is offline
Old 12-26-2008, 11:31 AM
BlessedHellride
BlessedHellride's Avatar
If you have an old school test light, you can turn the radio on and ground your test light to a suitable ground and stick the probe into the wires and the light will light up when it's on the positive side. Most of the time, the wires are two colors, one is a copper/bronze color and the other leg is usually a silver color. I always wired mine up as the copper color of the two were positive side and silver color negative.
BlessedHellride is offline
Old 12-26-2008, 11:37 AM
FivePointOhh
in limbo
FivePointOhh's Avatar
just twist the wires together and turn on the system. if the speaker sounds like its clicking or fuzzy you have them backwards.
FivePointOhh is offline
Old 12-26-2008, 11:39 AM
camaroeater
thanks guys... I finally came across a wiring diagram from an audio site.
1993 Ford Mustang Car Audio Wiring Schematic
Car Radio Battery Constant 12v+ Wire: Green/Yellow
Car Radio Accessory Switched 12v+ Wire: Yellow/Black
Car Radio Ground Wire: Chassis
Car Radio Illumination Wire: Blue/Red
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: Orange/Blue
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 5 1/4″
Car Audio Front Speakers Location: Doors
Left Front Speaker Positive Wire (+): Orange/Green
Left Front Speaker Negative Wire (-): Light Blue/White
Right Front Speaker Positive Wire (+): White/Green
Right Front Speaker Negative Wire (-): Green/Orange
Car Audio Rear Speakers Size: 5″ x 7″
Car Audio Rear Speakers Location: Side Panels
Left Rear Speaker Positive Wire (+): Pink/Green
Left Rear Speaker Negative Wire (-): Pink/Blue
Right Rear Speaker Positive Wire (+): Pink/Blue
Right Rear Speaker Negative Wire (-): Green/Orange
Old 12-26-2008, 11:45 AM
FivePointOhh
in limbo
i though you were talkin about just the speakers, not the harness itself. coulda told ya that.
jrrhd73must
10-02-2015 09:17 PM
breaking
10-02-2015 01:27 PM
Sixer4Life
09-29-2015 07:03 PM
Doogie65
09-06-2015 02:55 PM
TimeLord101
09-04-2015 09:27 AM
Quick Reply: speaker wires...which is postive/negative?
