cooling fan not working
Old 12-31-2008, 04:36 PM
jfdfire2
jfdfire2's Avatar
Default cooling fan not working
noticed today while sitting talking with friends that my 95 was running a bit hot after driving it a couple minutes the temp when right down. While looking into it i noticed that the cooling fan is not coming on. Can someone give me an idea where to start with this?
Thanks
jfdfire2 is offline
Old 12-31-2008, 06:17 PM
03sixbanger
Ryan's Backup Mod
03sixbanger's Avatar
thermostat going bad maybe
03sixbanger is offline
Old 12-31-2008, 07:06 PM
neo8222
neo8222's Avatar
next to the thermostat there's also a temperature sensor that the computer uses to figure out when to turn the fan on that could also be going bad.
neo8222 is offline
Old 01-01-2009, 12:55 AM
jfdfire2
jfdfire2's Avatar
I'm sure the thermostat is ok...when driving temperature stays like it should. the only time the car gets hot is when we are sitting still.
jfdfire2 is offline
Old 01-01-2009, 01:03 AM
96mustangv6
96mustangv6's Avatar
mine does it too lol must be a SN95 thing.
But umm, Turn on your A/C your fan should come on. While sitting still Turn your A/C on cold and Fan Speed on High, if the fan comes on then your Coolant Temp Sensor is out, if not than your fan is bad, Which is what happend to mine not to long ago. But mine was the sensor and the Fan.
96mustangv6 is offline
Old 01-01-2009, 01:04 AM
WhiteFoxGT
Resident Ford Troll
WhiteFoxGT's Avatar
Could also be a faulty CCRM
WhiteFoxGT is offline
Old 01-01-2009, 08:44 AM
jfdfire2
jfdfire2's Avatar
What is the CCRM???
jfdfire2 is offline
Old 01-01-2009, 11:43 AM
WhiteFoxGT
Resident Ford Troll
WhiteFoxGT's Avatar
Constant Control Relay Module
Its in the passenger fender area... They are known to go bad. But I wouldnt condemn it right away
Old 01-01-2009, 12:26 PM
red3.8_96stang
red3.8_96stang's Avatar
What you need to check is if the fan works, & if it does, what engine temperature does it come on at ?
You can run a jumper cable to check if the fan works ,direct from the battery. If it works then the problem is in the fan wiring or the fan control circuit. Check all wires & connections to the fan & if they are all good, it's likely the fan temp sensing circuit.
Be careful since you don't want anything to get caught in the fan blade if it starts up.
Years ago I had a Ford Fiesta, which the fan would come on too often, the opposite of your problem. Basically the engine only needed the fan if stuck in a traffic jam for 10 mins or more. I wired a relay & controlled the fan from inside the car. Worked better for me that way.
red3.8_96stang is offline
Old 01-01-2009, 01:03 PM
Matt's 95 Stang
Resident Ginger
Matt's 95 Stang's Avatar
Mine when bad a few months ago. The car would get hot even with the car running 65 on the freeway so I dont think its that. When my CCRM went out I couldnt run the car for more that 2 min without the car overheating so....I dont think its that. Good luck!
Matthew
Matt's 95 Stang is offline
Quick Reply: cooling fan not working
