Old 11-04-2015, 11:37 AM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Brake Guides
Print Wikipost
how to adjust E-brake mustang 2006 manual
Old 01-16-2009, 01:03 PM
johnny1973
johnny1973's Avatar
Default how to adjust E-brake mustang 2006 manual
Hi everybody ,
I am from Europe / Romania and at local Ford dealer they never had an Mustang inside ....so no way to get an help from them .
My car is an V6 coupe , 2006 , 5+1 manual speed .
I have an disequilibrium for rear end ebrake ... I have searched under the car and i have seen that the plate shown in the image ( the plate where the 2 rear cables join ) is not staying straight and when i pull the ebrake the left cable is tightened faster then the right cable ( i suppose that one of the cables is 2-3 mm shorter thats why the plate is slightly lop-sided ) . Does exist any bolt or screw or something to regulate the length of the cable ... or any sollution to fix them straight ?
Thanks in advance ,
Cristian .
ps. technical image could be viewed at :
http://picasaweb.google.com/maisonbo...68941396199490
i mention that i bought the car 3 months ago and i can not use the car because of this problem .... ( authorities has been checked the car and they told me is not suitable for driving ... pfff.... )
johnny1973 is offline
Old 01-16-2009, 01:15 PM
partsbill
partsbill's Avatar
SECTION 206-05: Parking Brake and Actuation 2006 Mustang Workshop Manual
GENERAL PROCEDURES
Parking Brake Cable Adjustment
CAUTION: Do not overtighten the parking brake cable adjustment nut. Overtightening will cause the brakes to drag or lock up.
1. Remove the access cover inside the floor console bin. (see figure 1)
2. Position the parking brake handle up at the fourth notch to access the adjuster nut.
3. NOTE: The rod is staked to prevent the removal of the nut. (see figure 2)
Loosen, but do not remove, the parking brake cable adjuster nut.
4. Apply the tension by tightening the parking brake cable adjustment nut until there is no lash in the system with the handle in the lowered position.
5. Cycle the parking brake control 4 times and adjust as necessary.
6. Lower the parking brake handle and install the access cover.
7. Test the parking brake system for proper operation.
Attached Thumbnails how to adjust E-brake mustang 2006 manual-figure-1.gif   how to adjust E-brake mustang 2006 manual-figure-2.gif
partsbill is offline
Old 01-16-2009, 01:18 PM
kingsofcrunk
kingsofcrunk's Avatar
So...before I was banned the first time (should I be posting that???) I made a write up on how to do this, which is on the How-To section:
https://mustangforums.com/forum/2005...cable-pix.html
kingsofcrunk is offline
Old 01-17-2009, 02:26 AM
johnny1973
johnny1973's Avatar
Hi Partsbill ,
I am not talking about this ..probably i was not so expllicite ...
I know how to tighten the central cable .... the only problem is that the small plate where are fixed the central cable and other 2 rear brake cables does not stay straight ....so the result is that when we use the ebrake one wheel brake is faster then the other ...at the result is an desequilibrium for the brake ( imagine that for example the rear left wheel brake cable is shorter then the right one ...when i use the brake the left wheel will start decelleration faster and the car will goes on a wrong direction not straight as normal )
Thanks ,
Chris .
GENERAL PROCEDURES
Old 01-17-2009, 02:32 AM
johnny1973
johnny1973's Avatar
there is the image for the plate ....
Old 01-17-2009, 03:12 AM
johnny1973
johnny1973's Avatar
Hi man ,
I have seen the posts but i am not concerned about this ..please check my link to see what i am talking about .
Chris .
Old 01-17-2009, 12:01 PM
157dB
Cut & Paste Expert
157dB's Avatar
Remove the parking brake handle and all associated hardware/cables.
Problem solved.
157dB is offline
Old 01-18-2009, 05:42 AM
johnny1973
johnny1973's Avatar
Problem solved.
VERY CLEVER ... !!!!
Old 02-15-2019, 01:45 PM
Xavier Lamontrey Williams
Xavier Lamontrey Williams's Avatar
Originally Posted by johnny1973
Hi Partsbill ,
Thanks ,
Chris .
I’m currently having this problem right now how did you fix it new line ?
Xavier Lamontrey Williams is offline
fxstb63
10-12-2009 09:13 AM
bigcanoe
08-01-2009 04:26 PM
zippo2341
01-13-2009 10:48 PM
ym42
12-25-2008 09:34 PM
Toddman0025
06-20-2008 08:15 PM
Quick Reply: how to adjust E-brake mustang 2006 manual
