01 bullitt heater core replacement
Old 02-09-2009, 08:45 PM
Donnie's GTS
Donnie's GTS's Avatar
Default 01 bullitt heater core replacement
Honestly how difficult is this to do? Mines shot, leaking cooling inside my car, and i need to replace it asap.
Donnie's GTS is offline
Old 02-09-2009, 08:52 PM
william_ace
william_ace's Avatar
well they certainly aren't easy to change out. if its anything like my 96 you have to take out the entire dash and set it on the seat. remove the steering column and do the same lay it down in the seat. unplug all sorts of harnesses, go into the engine bay and disconnect the hoses. i've done it once and it took me 4 hours. its doable, just time consuming.
william_ace is offline
Old 02-09-2009, 09:05 PM
Donnie's GTS
i think im going to attempt it tomorrow then, i have haynes, and found a good write-up on how to.
Old 02-09-2009, 09:25 PM
Davojan59
Davojan59's Avatar
good stuff, once ur done share ur write up if it helped u a lot. Im sure we could all use it in case we need it later. Heater core will go sooner or later.
Davojan59 is offline
Old 02-10-2009, 03:03 AM
crash
BrandofPoop
crash's Avatar
Good luck! mine went out about 2 months ago. Luckily I had a friend do it for me. I wasn't about to tackle that ****.
crash is offline
Old 02-10-2009, 11:12 AM
Donnie's GTS
lol, thats inspirational.
Old 02-10-2009, 04:27 PM
crash
BrandofPoop
crash's Avatar
I'm sure you're way more qualified than I am lol
crash is offline
Old 02-10-2009, 04:38 PM
ChalknCover
Sgt. Killjoy
ChalknCover's Avatar
It really depends on your skill level. If you feel like you know what you are doing and have a good set of instructions to go by, you should be fine. If you are really uncertain, then I would leave it to someone else. It is time consuming though. According to my database, a ford tech should be able to do it in 4 hours, a typical diy'er will be looking in the 5.5-6.0 range
ChalknCover is offline
Old 02-10-2009, 06:22 PM
mustangman03
mustangman03's Avatar
It took me 4 hrs. doing mine and that was the first on ever if I can find a print out i will put it up it isnt a bad job though you have to remove the left inner fender liner to disconnect a bulk head connector.
mustangman03 is offline
Old 08-12-2013, 12:27 PM
goldengod732
goldengod732's Avatar
can someone please link me to a good write up on replacing the heater core in a 01 bullitt? i need to do mine this weekend
goldengod732 is offline
5.0muscle
01-11-2016 01:17 PM
9550
10-26-2015 05:01 PM
Golfsito
10-06-2015 11:02 AM
MusicCity615
09-12-2015 07:05 AM
Art161
09-09-2015 10:33 AM
Quick Reply: 01 bullitt heater core replacement
