proper way to put on thermostat
Old 06-11-2005, 01:07 AM
099gt
099gt's Avatar
Default proper way to put on thermostat
i had coolant coming from the thermostat so i went out and bought a 180 degree therm. and new rubber seal with it. and the thing still leaks is there some special way to put it on?
099gt is offline
Old 06-11-2005, 02:02 PM
099gt
099gt's Avatar
Default RE: proper way to put on thermostat
come on i no a few of u have done thermostats has any of yours leaked after u put it on
099gt is offline
Old 06-11-2005, 02:07 PM
badass04gt
badass04gt's Avatar
did you use silicone sealer (rtv) on both sides of the gasket and the housing?
badass04gt is offline
Old 06-11-2005, 03:10 PM
099gt
099gt's Avatar
no.....the could be the problem i didnt see any old sealer on it so i thought u could just replace it
099gt is offline
Old 06-11-2005, 04:30 PM
devinsteen
devinsteen's Avatar
Sounds like you have a cracked manifold[] THey usually crack out the t-stat housing....same thing happend to me. I thought it needed a new o-ring,, but it turned out there was a crack inside the t-stat housing.
devinsteen is offline
Old 06-11-2005, 04:32 PM
badass04gt
badass04gt's Avatar
On my camaro, the same thing happened. After 2 new thermostats i used the rtv on the gasket and it was fine. If that doesnt work you prob do have a cracked t-stat housing or manifold like devinsteen said.
Old 06-11-2005, 05:08 PM
Casper98GT
I ♥ Acer
Casper98GT's Avatar
First remove the 2 bolts... remove rubber gasket and then thermostat. Put in new thermostat, put rubber o-ring/seal over it and put hose back on and tighten bolts down.... If it doesnt work something is wrong.
Casper98GT is offline
Old 06-11-2005, 06:28 PM
mustang_montana
mustang_montana's Avatar
hes got a 99 though, so its not likely to be a crack manifold. sometimes when i change o rings i bolt em down too tight so they twist and leak. definetly unbolt it and check, and use the gasket sealer..it saves lives.
mustang_montana is offline
Old 06-11-2005, 06:54 PM
Acer2428
Site Mod
Acer2428's Avatar
99's were just as bad. THey didn't use the alum. crossover until late '01.
Acer2428 is offline
Old 06-11-2005, 07:17 PM
devinsteen
devinsteen's Avatar
ORIGINAL: Acer2428
Thank you Acer. Like I said, it might be cracked....hopefully it's not. But it's not just going to leak coolant for no reason.
Quick Reply: proper way to put on thermostat
