SVT Forums
1997 Mustang Cobra missing... PLEASE HELP!!!!
Old 03-06-2009, 10:12 PM
chadwick108
chadwick108's Avatar
Default 1997 Mustang Cobra missing... PLEASE HELP!!!!
hey guys hopefully someone knows something that is going on...cobra had been missing... had double platinums in it which don't seem to do well at all any way. Changed them out because i thought that is what was making it miss...put ngk plugs back in it.... it is still missing on cylinders 2 AND 6...what the crap is going on??? someone told me that it could be a pressure regulator or temp sensor. Just wanted to get a second opinion. any help is greatly appreciated.
chadwick108 is offline
Old 03-06-2009, 10:50 PM
SVTeeshirt
SVTeeshirt's Avatar
did u do wires as well? could be ur problem.
Lol when u said missing for a second i thought u ment someone stole it.
SVTeeshirt is offline
Old 03-07-2009, 12:16 AM
P.S.I.cho
P.S.I.cho's Avatar
need a little more info to help you out, you need to test to see if the spark plug in those cylinders is firing correcty, secondly what ngks did you put in there deviating from a stock heat range plug or higher resistance electrode can cause problems, third your gonna have to test fuel pressure and injectors to make sure they are working. test fuel last usually its the harder of the tests
P.S.I.cho is offline
Old 03-07-2009, 10:25 PM
pitmitch910
pitmitch910's Avatar
hahaha same, but def get motorcraft plugs and try changing the wires id start there for sure and change the fuel filter and get a good fuel system cleaner to run through it wouldnt hurt
pitmitch910 is offline
Old 03-10-2009, 03:49 PM
chadwick108
Angry obd II scan
Took car to town and had it scanned. Turns out it showed up as 2 different codes p1131 and p1443 don't think that they are related. Checked for spark and car has spark while running. Maybe a fuel problem. Went to ford yesterday and got some prices on parts.
Any advice on what to do first?
coolant temp sensor $26.01
fuel press regulator $88.56
plug wires $78.41
could it be an O2 sensor problem?
Old 03-10-2009, 05:59 PM
pitmitch910
what did the codes come up to be?
Old 03-11-2009, 07:26 AM
alexr
alexr's Avatar
you should be a little more descriptive/selective with your wording. your thread title seems to be implying that your car was stolen, not misfiring.
alexr is offline
Old 03-11-2009, 09:06 AM
MAD SVT
MAD SVT's Avatar
found online..
"Straight from the service cd (mostly, I added a descriptor after the code)
P1443=A problem with the EVAP purge flow system
Continuous Memory Diagnostic Trouble Code (DTC) P1443 indicates an incorrect evaporative system purge control valve flow.
Possible causes:
-- Obstructed, open or cracked hoses between EVAP canister purge valve and intake manifold.
-- Damaged EVAP canister purge valve.
-- Damaged PF sensor.
P1131=Bank 1 upstream (front) O2 not switching properly showing that it thinks Bank 1 is going lean. Bank 1 may be going lean from what you say about a closed loop fuel issue.
Diagnostic Trouble Codes (DTCs) P1131 bank (1) (Cylinder #1) and P1151 bank (2) indicate the fuel/air ratio is correcting rich for an overly lean condition. The HO2S voltage is less than 0.45 volt. DTCs P1132 bank (1) (Cylinder #1) and P1152 bank (2) indicate the fuel/air ratio is correcting lean for an overly rich condition. The HO2S voltage is greater than 0.45 volt.
DTCs P1130 and P1150 indicate the fuel control system has reached maximum compensation for a lean or rich condition and the HO2S is not switching.
DTC/HO2S Reference List
-- HO2S-11 = DTCs P1131, P1132 and P1130
-- HO2S-21 = DTCs P1151, P1152 and P1150
Possible causes:
Fuel system
-- Excessive fuel pressure.
-- Leaking fuel injector(s).
-- Leaking fuel pressure regulator.
-- Low fuel pressure.
-- Contaminated injector(s)
Induction system
-- Air leaks after the MAF.
-- Vacuum leaks.
-- Restricted air inlet.
-- PCV system.
-- Fuel purge system.
-- Improperly seated dip stick.
EGR
-- Leaking gasket.
-- Stuck open EGR valve.
-- Leaking diaphragm.
Base engine
-- Oil overfill.
-- Cam timing.
-- Cylinder compression.
-- Exhaust leaks before or near the HO2Ss."
MAD SVT is offline
Diode Dynamics
28
05-26-2022 12:02 PM
Urambo Tauro
09-07-2015 12:47 PM
svtrosey
SVT Forums
08-15-2015 09:09 PM
Boostaddict
Lethal Performance
08-13-2015 01:57 PM
daytooday
08-11-2015 09:22 AM
Quick Reply: 1997 Mustang Cobra missing... PLEASE HELP!!!!
