koeo codes
Old 03-16-2009, 11:21 PM
lx5.0
lx5.0's Avatar
Default koeo codes
i ran a test to see what codes i would get and this is what i got
31 - EGR Valve Position/Pressure Feedback EGR Circuit Below Minimum Voltage. 0.24 volts (O,CM,R)
81 - Secondary Air Diverter Circuit Failure (O)
82 - Secondary Air Bypass Circuit Failure (O)
84 - EGR Vacuum Regulator (EVR) Control Circuit Failure (O)
85 - CANP Circuit Failure (O
are these codes my emissions stuff cause ive deleted them i dont know about code 81 and 82 is that emissions also
lx5.0 is offline
Old 03-17-2009, 01:55 AM
94ford5liter
94ford5liter's Avatar
Pretty sure those are all smog related, dealing with what you removed. Did you remove the egr as well? Cause I think that first code is a bad a egr sensor otherwise.
94ford5liter is offline
Old 03-17-2009, 06:39 AM
Joel5.0
Joel5.0's Avatar
81, 82 and 84 are for the three solenoids behind the RH side strut tower being disconnected/missing.
85 is for the CANister Purge solenoid being disconnected/removed.
31 is for the EGR sensor being disconnected/removed.
In your setup, it's the equivalent of a "system pass".
Joel5.0 is offline
Old 03-17-2009, 12:44 PM
KJMac
KJMac's Avatar
Could you give me a little help with my codes?
111-pass code? what is a pass code?
165?
536-Brake on/off....replaced it
Thank You
KJ
KJMac is offline
Old 03-17-2009, 01:22 PM
Joel5.0
Joel5.0's Avatar
111 - no fault codes registered for that self test routine.
165 - no clue, it doesn't show as a valid KOEO or KOER self test code
536 - Brake On/Off circuit failure / switch not actuated during KOER test
If the fault code was logged during a KOER, it means you forgot to press the brake pedal after the engine ID code was displayed (4 = 8 cylinders engine), not that the switch was at fault...... LUK.
Joel5.0 is offline
Old 03-17-2009, 08:15 PM
KJMac
KJMac's Avatar
Thank you for the help! Should I reset the computer ? I'm going out now to clean the MAF and change plugs. and test drive....I hope it isn't the fuel pump!
KJMac is offline
BOB ROME
07-26-2023 01:54 PM
mrtrodonet
09-19-2020 03:12 PM
lincolnshibuya
12-08-2015 04:37 PM
Dathan
10-05-2015 05:52 AM
ChampInSD
10-02-2015 04:55 AM
Quick Reply: koeo codes
