351 cam in a 302?
Old 03-17-2009, 09:54 PM
69RunningHorse
69RunningHorse's Avatar
Default 351 cam in a 302?
i just heard about this, is it really that beneficial? swap a 351 cam into a 302 and wire the plugs as 351. Anyone ever done this?
69RunningHorse is offline
Old 03-17-2009, 10:17 PM
my77stang
my77stang's Avatar
the 351w uses a different (and better) firing order, ford started using the 351w firing order on 302's in the roller motors.
my77stang is offline
Old 03-17-2009, 10:24 PM
69RunningHorse
so it wont it make a diff if i got a 94-95 gt ho motor, then will it?
Old 03-17-2009, 11:35 PM
htwheelz67
htwheelz67's Avatar
nope it wont
htwheelz67 is offline
Old 03-17-2009, 11:46 PM
69RunningHorse
that's what i thought thanks for the good info guys!
Old 03-18-2009, 12:29 AM
racin66coupe
racin66coupe's Avatar
so, if the 351 firing order is better, can you put a 351w cam in a 289/302 and just run the 351 firing order?
racin66coupe is offline
Old 03-18-2009, 01:33 AM
rmodel65
Yukon Cornelius
rmodel65's Avatar
the HO motor uses the 351w firing order already, keep in mind a mild cam on 351 will be hotter because of the less cubic inchs
rmodel65 is offline
Old 03-18-2009, 10:02 AM
69RunningHorse
that's the theory...
Old 03-18-2009, 10:12 AM
kalli
kalli's Avatar
as what 69RunningHorse says.
here's the theory
you have four cycles: intake, compression, work and exhaust.
through those cycles the camshaft only turns once, but the crankshaft twice.
so the piston is fully up when engine ignites but again when it just pushed out the burned mixture through exhaust valve.
When you fire is regulated by firing order. the valves are regulated by the camshaft.
here's the 289 firing order
1-5-4-2-6-3-7-8
and here's the 351
1-3-7-2-6-5-4-8
you see the 1st, 4th, 5th and 8th cylinder fired are the same
1-x-x-2-6-x-x-8
and the 5-4 and 3-7 order is just interchanged.
No change on crankshaft, just the valve opening is turned at 180 degrees on cam on those 4 cylinders. firing order changed, job done.
kalli is offline
Old 03-18-2009, 01:53 PM
nassaubayman
nassaubayman's Avatar
What is the benefit of the different firing order? More horespower? Better gas mileage? The car will magically wash and wax itself?
nassaubayman is offline
Quick Reply: 351 cam in a 302?
