Removal and installation of steering wheel for S197
Old 03-19-2009, 02:43 PM
CutterWolf
CutterWolf's Avatar
Default Removal and installation of steering wheel for S197
Removal and installation of steering wheel for S197.
Tools needed: Socket wrench
Torque wrench
8mm socket
24mm socket
Very small flat head screw driver
1. Disconnect the battery (ground) and wait 5 to 10mins to insure the power has drained out of the system. If you want you can also pull the airbag fuse from the SJB found on the passenger side kick panel fuse #17 which is a 10 amp fuse.
2. Pull off the two plastic caps on the sides of the wheel to access the two bolts that hold the airbag
2. Unscrew bolts with 8mm socket
3. Pull off the airbag assy and disconnect the two electrical connectors. Just pinch the side of the connector and pull up.
4. Disconnect the cruise control electrical connector, you will see a tab at the top of the connector, use a small flat head screw driver to lift up the tab and pull out on the connector to remove.
5. Use a 24mm socket to remove the main steering wheel bolt. (no wheel puller is needed.)
6. Remove wheel.
7. Reinstall new wheel in reverse order making sure to torque the retaining bolt down to 41 foot pounds and its set.
The whole thing took about 20 minutes.
CutterWolf is offline
Old 03-19-2009, 03:05 PM
nmd55
nmd55's Avatar
what steering wheel did u replace it with?
nmd55 is offline
Old 03-19-2009, 03:08 PM
PennState
PennState's Avatar
nice write up. It's very easy, did it last summer in like 10 mins with no clue of what i was doing.
PennState is offline
Smooth_J
Smooth_J's Avatar
Looks like the SVT black on black (like the one I have).
Nice I should of made a how to when I did mine, but it was around 12AM :P
By the way, you should use more blue loctite on the bolt (just to be safe).
Smooth_J is offline
Old 03-19-2009, 03:10 PM
CutterWolf
CutterWolf's Avatar
Yep, that's the one. Was going to get it with the red stiching but I don't have any red in my car so black on black was the way to go. Also made myself a custom center cap.
Old 03-19-2009, 03:12 PM
MustangGT0405
MustangGT0405's Avatar
Looks great
MustangGT0405 is offline
Old 03-19-2009, 03:23 PM
Smooth_J
Smooth_J's Avatar
By the way, nice gearworks set you have. I just purchased new sockets/wrenches from them.
Good quality stuff
Smooth_J is offline
Old 03-21-2009, 09:59 PM
CutterWolf
CutterWolf's Avatar
Sticky please!
Old 03-21-2009, 10:21 PM
mygt500
Multi-Tasking Moderator!
mygt500's Avatar
Ask and yee shall receive!!!!! I know you sent me a PM and I needed an link but here it is!!!!!! I believe joolander asked to do this this for us too! (write up)
Thanks Barry and it will be stickied! (give me time at work and busy since we last wrote)
Joo or Matt if you see this feel free to add it to the Sticky in the 2005+ section! thanks Jason
mygt500 is offline
Old 03-21-2009, 10:26 PM
Srt2Stang725
Srt2Stang725's Avatar
nice write-up...ill be doing this tomorrow, this will come in handy even though it seems easy. Its always nice to see what has to be done before you do something
Srt2Stang725 is offline
Quick Reply: Removal and installation of steering wheel for S197
