Temperature Gauge Fluctuation
Old 04-12-2009, 06:49 PM
pizon
pizon's Avatar
Default Temperature Gauge Fluctuation
What could cause my temperature gauge to fluctuate between normal and hot if my my RPMs and speed are in sync? I've also noticed my heater will blow cold air at times. Thermostat, radiator?
pizon is offline
Old 04-13-2009, 08:47 AM
bgnn32
bgnn32's Avatar
I would start with the thermostat, could be the cause of the problems you listed.
bgnn32 is offline
Old 04-14-2009, 01:18 PM
g_unotkiller
g_unotkiller's Avatar
having the same problem, tried bleeding the cooling system worked for awhile but now car oveheats and heater blows cold air. wonder if i need a new radiator
g_unotkiller is offline
Old 04-14-2009, 01:27 PM
bgnn32
bgnn32's Avatar
Have you replaced the Thermostat?
Radiator failures are rare unless you punctured it or something similar.
bgnn32 is offline
jwog666
12-27-2021 08:09 PM
andrew1969
16
01-08-2016 02:48 PM
svfetter
10-05-2015 11:39 AM
Pyrate Dave
09-10-2015 07:30 PM
Quick Reply: Temperature Gauge Fluctuation
