Bad Throw Out Bearing?
Old 04-15-2009, 01:03 PM
amhsraptor
amhsraptor's Avatar
Default Bad Throw Out Bearing?
I have been having a problem in 5th gear. Around 2500rpms I hear a loud rattling noise coming from the transmission. After I go over 3000rpms it essentially goes away. One of my neighbors, a big ford guy, suggested that it sounds like the throw out bearing. Does this sound like it is the throw out, or is something possibly wrong with the transmission?
BTW, I have gone throw 2 transmissions, and the 3rd cluster gear shattered in my old one.
-Brian
amhsraptor is offline
Old 04-15-2009, 01:11 PM
FivePointOhh
in limbo
FivePointOhh's Avatar
learn how to drive. lol
do you hear any chattering when in nuetral foot off the pedal?
FivePointOhh is offline
Old 04-15-2009, 01:29 PM
amhsraptor
amhsraptor's Avatar
small and insignificant. but what got my attention was 5th gear. and i dont see how that is relevant to driving
Old 04-15-2009, 02:58 PM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
I would think that if it was the t/o bearing, it would make noise in all gears.
PRO50SC is offline
Old 04-15-2009, 03:14 PM
amhsraptor
amhsraptor's Avatar
It makes some noise but it becomes noticeable in 5th gear, I am away at college atm so it is hard to recall everything. But I am positive it makes noise in other gears, but you have to listen very carefully otherwise you wont notice it.
Old 04-18-2009, 01:01 AM
Jfsram
Jfsram's Avatar
A throwout bearing doesn't care what gear you are in. If there is a noise concerning a throwout bearing. With the engine running try the pedal up, a slight amount of pressure or to the floor. If the noise changes it's throwout bearing or clutch related.
If you shattered a cluster gear for no apparent reason. Check out what I did to my cluster.https://mustangforums.com/forum/memb...2-img-0521.jpg
This is my replacement cluster from TTC. It's a genuine Tremec brand part and the broken one looks very different in quality, finish and colour. New one on the right. Broken imitation on the left.
https://mustangforums.com/forum/memb...3-img-0522.jpg
Jfsram is offline
Old 04-18-2009, 01:30 AM
TrimDrip
FudgeDrip
TrimDrip's Avatar
i do in mine, you know what it is?
TrimDrip is offline
Old 04-18-2009, 09:46 AM
projectresto83
M.A.D. Motorsports
projectresto83's Avatar
Trim, if you push in the peddle does it go away? OP you should check your u joints and everything else that has to do with and around the trans too and make sure nothing is loose.
projectresto83 is offline
Old 04-18-2009, 10:42 PM
TrimDrip
FudgeDrip
TrimDrip's Avatar
yeah, I think so. It starts doing it again at WOT in 3rd and 4th gear.
TrimDrip is offline
BOB ROME
07-26-2023 01:54 PM
lovesilver
Members Mustangs
05-09-2019 09:18 PM
Dathan
10-05-2015 05:52 AM
UrS4
09-30-2015 10:13 AM
GLOCKer
09-28-2015 07:36 AM
Quick Reply: Bad Throw Out Bearing?
