USED AFR 165 HEADS (ON BUDGET)
Old 04-17-2009, 05:44 AM
Chingky001
Chingky001's Avatar
Question USED AFR 165 HEADS (ON BUDGET)
My Car is a 1988 mustang GT mustang 5.0 and have these mods:
bbk cold air intake, with 70mm throttle body and 70mm spacer 73mmC&L MAF
msd distributer, msd 6al ingnition box, and i tfi msd coil
a billet adj. fuel regulator (30-100 psi), 24lb fuel injectors,
bkk long tube headers
bbk h-pipes w/o cats
flow master 2 chamber exaughst (american Thunder)
cobra intake (i think but it look like a normal one to me)
a rebuilt (i think it is) t-5 short shifter
i've had my dizzy done and set
WOULD THESE HEADS HELP ME OUT? AND WHERE COULD FIND IT
Chingky001 is offline
Old 04-17-2009, 06:55 AM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
of course they'd help, try ebay or craigs list but no aluminum head is gonna be cheap, expect to spend 900.00 to 1100 for a used aluminum head pending what brand, I have a set of edelbrock rpm 1.90/1.60's for 875.00
mjr46 is offline
Old 04-17-2009, 09:23 AM
Chingky001
Chingky001's Avatar
Question
how long have you had them and do you still have the reciept because i want to document everything i get for my car
Old 04-17-2009, 09:40 AM
rando12
rando12's Avatar
if you want to keep on a budget you can take your e7te heads and have 2.02/1.60 cut into them then do a little port work and they flow the same as afr165. I looked at having it done and it came to 450 including valves from my machinest.
rando12 is offline
Old 04-17-2009, 10:04 AM
Portmaster
Portmaster's Avatar
Did you fall down and hit your head on something or did your machinest hold a swinging watch out in front of you for a few minutes? lol
Portmaster is offline
Old 04-17-2009, 10:10 AM
Portmaster
Portmaster's Avatar
If you want a reciept you get it from the person you buy them from stating you bought them used and appox mileage if possible. Getting the recipt from where they were purchaced new falsifies the trure documentation of your build. It would be like me asking the previous owner of my 85 Coupe for the dealer invoice to put in my build records.
Old 04-17-2009, 10:14 AM
rando12
rando12's Avatar
I have been told by a coupe diffrent machinests that they will. Its just one way to get a little better flowing head on a budjet.
rando12 is offline
Old 04-17-2009, 11:05 AM
mjr46
mjr46's Avatar
they are about 1 year old and were purchased at a local speed shop for 1175.00, no I don't have reciept anymore
mjr46 is offline
Old 04-17-2009, 11:10 AM
mjr46
mjr46's Avatar
if you say so.
mjr46 is offline
Old 04-17-2009, 12:48 PM
67mustang302
67mustang302's Avatar
There's no way in HELL you will EVER get a set of ported E7's to perform like a good set of aftermarket heads. Granted, a good set of ported stockers can do well, but a good set of aftermarket heads with revised port designs are always going to be ahead of the game. And there's a lot more to making power than just what the head flows after it's been ported.
67mustang302 is offline
Quick Reply: USED AFR 165 HEADS (ON BUDGET)
