SVT Forums
PATS problem! plz help asap
Old 05-03-2009, 09:39 AM
BlackLX_92
BlackLX_92's Avatar
Default PATS problem! plz help asap
ok so i think im having problems with my pats system i just put a new motor in my car and its not wanting to start now its turning over but no fire. i was told its prolly done becuz of my pats system is there anyway i can disable/ bypass pats with my sct tuner?
BlackLX_92 is offline
Old 06-28-2009, 05:27 PM
akagreg
akagreg's Avatar
i got the same problem change my heads and the car wont get fire i refuss to have my car towed to a dealership for my pats to be reprogramed this is a conspiracy becuse ford did not take the bailout sct wont work it wont even read the tuner iv found in the fourms that a Directed E Bypass modules for ford mabe a way to bypass the pats ? think ill try one first 20$ on the net found on road dead
akagreg is offline
Old 06-28-2009, 06:12 PM
1999 GT
1999 GT's Avatar
change the fuse under the hood of your car, in the ford fuse box i thin it is like the 3rd one down it is yellow and has the number 10 on it, my buddys cobra did the same thing, and now shes back and running, its a 2 dollar fuse from auto zone...
1999 GT is offline
Old 06-28-2009, 08:39 PM
akagreg
akagreg's Avatar
my cars been down for month if it was just a fuse that be nice sins the car ran find before i took it apart and all the fuse look good i dont think its that but im willing to try any thing hell ill change all the fuses in the hole car
akagreg is offline
Old 06-28-2009, 08:58 PM
Smokin04
Smokin04's Avatar
If it was a PATS problem, the THEFT light will be flashing rapidly while trying to start the car.
Smokin04 is offline
Old 06-29-2009, 11:07 AM
5.0 85 GT
5.0 85 GT's Avatar
ya the thef tlight should be flashing like mad, trust me tho dud eit was cobra that had the fuse, the thing would crank but not turn over or not crank at all, so i also didtn belive it was a fuse, i took apart the steering column everythign, and i was laughing as i turned the key when i replaced the fuse becaus4e it fired right up, it was the stupidest thing ever, i carry a back up one in my center console, so trust me...do that
5.0 85 GT is offline
Old 06-29-2009, 03:24 PM
akagreg
akagreg's Avatar
my car theft light is flashing then stop then does one flash then flash about 6 times repeats yup just went and check to make sure so i did fill stuiped it flash wille trying to start the car like i said ill change all the fuse in the car if that will fix it without take it to the dealer or a locksmith dealer 80$ to reprogram pats locksmith 150$ to come over
akagreg is offline
Old 07-03-2009, 08:19 PM
5.0 85 GT
5.0 85 GT's Avatar
no replace tat fuse, it number ten its yellow it is 3rd down from the top in the fuse box cover under the hood on the drivers side....do that..ahaha
Old 07-07-2009, 04:23 PM
akagreg
akagreg's Avatar
check all your grounds theres one under the battery that goes to the fuse box that was my problem and two that go to the moter mount good luck
akagreg is offline
Old 07-10-2009, 03:06 PM
Caturix
Caturix's Avatar
Hmmm...Since this is a PATS thread I think I'll throw my PATS problem out there...A lil while ago I broke a key off in the ignition so I took it to the Ford dealership in Manchester where they supposedly programed a new key to my car...But now when I start it I have to have the old key held up to the new one...Guess I may have to keep doing this till I get the time/money to get it programed right.
Caturix is offline
Quick Reply: PATS problem! plz help asap
