SVO Forum
Fuel Pump Questions
Old 05-23-2009, 08:36 PM
t23175210
t23175210's Avatar
Default Fuel Pump Questions
Yesterday, while putting the plates back on my car for the summer, my car was idling then it stalled. Fuel Pump **** the bed. If I remember correctly, svo's have two fuel pumps, and people usually add one bigger fuel pump. Is this true? If it is, could someone post a link to the pump I need to get?
Thanks alot
t23175210 is offline
Old 05-24-2009, 07:31 PM
fast65
fast65's Avatar
Well not all SVO's had two fuel pumps, the 84 and 85 SVO's had an intake pump and then a frame mounted pump on the passenger side of the car. What a lot of people do is replace both the pumps with a high output Walbro 255 lph pump.
fast65 is offline
Old 05-24-2009, 08:46 PM
t23175210
t23175210's Avatar
well mine happends to be an 84. is the walbro a in-tank pump? i have acess to a lift and i have a tranny jack i can use to lower the tank. while i have the car on the lift, i would prob change the rubber fuel lines to hard ones.
thanks
Old 05-25-2009, 02:39 PM
fast65
fast65's Avatar
Yeah the Walbro is an in-tank pump, you can also replace the frame mounted pump with another fuel filter from a '93 (I think) Ranger with the V6. Here's a link to a Walbro pump but I don't think it's the high-output one.
Walbro
fast65 is offline
Old 05-30-2009, 10:59 PM
t23175210
t23175210's Avatar
Should I replace the stock fuel pressure regulator with an aftermarket model with this bigger pump? I don’t plan to boost the car any higher than 15lbs.
Just want to make sure before I buy everything so I only have to place one order.
Thanks again
Old 06-01-2009, 12:02 AM
fast65
fast65's Avatar
Thanks again
To the best of my knowledge you don't need an adjustable fuel pressure regulator if you're only going to run 15 psi.
fast65 is offline
Old 07-21-2009, 05:36 PM
safado
safado's Avatar
I'm not sure.. but on the Xr4ti's the in tank pump is behind a resistor wire... so the wiring to it needs to be upgraded to run just one pump...
safado is offline
Tivo304
08-28-2023 12:19 PM
raleigh05GTO
09-04-2015 07:09 AM
5.0 kevo
09-03-2015 06:24 PM
SYNY5TER
09-02-2015 01:35 AM
Quick Reply: Fuel Pump Questions
