351 Mustang
stock timing for 351w?
Old 05-25-2009, 06:24 PM
Slowstang357
Slowstang357's Avatar
Default stock timing for 351w?
Anybody happen to know the stock timing on a 351 windsor for idle? I had the timing advanced quite a bit for racing but i just want to street drive it now.
Thanks!
Slowstang357 is offline
Old 05-27-2009, 04:51 PM
wrenchturner75
wrenchturner75's Avatar
what ill do is use a vacumn guage, ill advance the timing till i reach the highest vacumn reading and tighten the dizzy down, of course i do this with the motor at temp. shut it down and leave it off for about 2 min then try to restart, if it starts slow or sluggish ill back it off till it stops. then drive it and check for pinging. if it pings you can dial out some timing with the vacumn advance if you have one.
wrenchturner75 is offline
Old 05-27-2009, 04:55 PM
wrenchturner75
also im sure your windsor has quite a bit of cam in it, and the cam will not like base timing specs guaranteed, they like lots of initial timing, the vacumn guage will let you see where the engine is the happiest. good luck
Old 05-27-2009, 10:35 PM
Slowstang357
no the engine has carb, intake and headers the rest is stock
Old 05-30-2009, 02:15 AM
Matty
Matty's Avatar
10* is stock. I use 13-14 on the street with the good gas.
Matty is offline
Old 05-30-2009, 03:01 AM
vristang
vristang's Avatar
Thanks!
Seriously?
Is that your car in your sig?
Are you driving it?
And you don't know how to set the timing for 'street driving'????
Something fishy here
vristang is offline
Old 05-31-2009, 01:04 AM
Slowstang357
thanks.
drfister
05-03-2018 10:38 PM
Spiral534
10-06-2015 04:31 PM
YoungStangsMan
09-05-2015 07:01 PM
GimpyHSHS
08-29-2015 06:30 PM
ding56
08-14-2015 02:40 AM
Quick Reply: stock timing for 351w?
