stangant's engine build thread
Old 06-02-2009, 05:28 PM
stangant
stangant's Avatar
Default stangant's DIY engine/turbo build thread
CAR HAS ON IT:
**Interior**
Ford Racing short shifter
Hurst "T" shift ****
Mach1 Tweeter pods
Mach1 back deck panel
01 Center console
Boost Gauge
fuel pressure Gauge
Wide band
*ALL GAUGES ARE RED DIGITAL*
steering wheel gauge pod
cobra a pillars
black/charcoal Interior conversion
air bag delete
4 point roll cage
5 point race harness's
Corbeau CR1 race seats
**Exterior**
01-04 gt side scoops
Saleen race wing
4.5" Kaenen cowl hood
Hood strut kit
4.2L badges
8" shorty antenna
gt star fish rims
Blacked out headlights
03-04 Cobra Front Bumper
+ Chin spoiler
+ fogs
sequential tail lights
rear blackout panel
**Suspention**
Roush Lowering Springs
Monroe shocks/struts
steeda x2 ball joints
steeda rear sway Bar
Cobra Brake conversion (front)
MM Caster camber kits
Steeda bumpsteer kit
QA1 Tubular K member
**Performance**
Battery relocation kit
oem coil pack
oem replacement spark plug Wires
8.8 rear end swap
live wire tuned
snow performance stage 2 meth injection
Slot style m.a.f
T70 turbo setup
Tial 38mm wastegate
Blitz supersound bov
60# injectors
Power Steering delete
a/c delete
Cobra fuel hat conversion with wire upgrade
2x 255lph Walbro fuel pumps
Engine build specs:
Ross Forged 4.2 pistons .030
Forged connecting rods
4.2 Crank
Gapless piston rings
stage 2 heads by hiposilver
p&p lower intake manifold
head studs
PICS:
stangant is offline
Old 06-02-2009, 05:41 PM
Fink
Fink's Avatar
What TT set up are you going to run? STS or under hood?
Fink is offline
Old 06-02-2009, 06:22 PM
stangant
stangant's Avatar
custom underhood
stangant is offline
Old 06-03-2009, 11:53 AM
stangant
stangant's Avatar
stangant is offline
Old 06-03-2009, 12:30 PM
ESG-642T
Buyer Beware
ESG-642T's Avatar
You need a horsepower goal not just a "15-25 psi"
1.) I would consider a more custom cam than a 218/224
2.) I would consider doing a 4.2L stroker if your going to do all the work
ESG-642T is offline
Old 06-03-2009, 12:55 PM
stangant
stangant's Avatar
stangant is offline
Old 06-03-2009, 01:21 PM
Shaunmac9128
Shaunmac9128's Avatar
I belive its bore and isn't the 4.2 just a stroked out version of the 3.8? He's probably referring to the custom 4.2 you can get through ssm...not sure though.
Shaunmac9128 is offline
Old 06-03-2009, 04:40 PM
ESG-642T
Buyer Beware
ESG-642T's Avatar
Exclamation
Originally Posted by stangant
well thats my build, i have no HP goal what ever it turns out to be in the end is what i'm happy with. the cam was picked out by the guys a supersixmotorsports.com.
When u say 4.2L do u mean the truck engine? If so then noway, i am sticking with the mustang block with no boar just a polish down and thats it.
SuperSix tells anybody doing anything to get that cam, does it work? sure its just not very application specific.
I'm saying if your (actually) going to go through and spend money why not go ahead and get the 4.2/3 L stroker kit from ssms? If your going to try and do a twin kit, and everything might as well get the most out of everything right?
ESG-642T is offline
Old 06-03-2009, 04:45 PM
Xemeth
Xemeth's Avatar
OK, so you have valve covers and UDP's, and that big long list is stuff you still need?
Sorry, I don't even see this thing getting done. If I recall correctly you've had "plans" for this build for quite a while, and all you have is about $300 worth of stuff (if that). Just cause you made a list of all the parts you need doesn't mean you're any closer or are actually going to finish.
Sorry, I've just seen a bunch of people with minimal bolt ons say "Oh I'm gonna do this, this, and this!" and then they sell the car or something.
Xemeth is offline
Old 06-03-2009, 05:09 PM
stangant
stangant's Avatar
THIS WILL BE DONE.~~~~~~~
stangant is offline
Quick Reply: stangant's engine build thread
