8.8 rear end swap in 66
Old 06-28-2009, 07:18 PM
TBS66
TBS66's Avatar
Default 8.8 rear end swap in 66
I'm thinking of installing a 8.8 in my 66, I have most of the information I need for the install except the driveshaft. Is there a adapter that can go on the 66 driveshaft or will I need a complete new one? I'm running a 289 with a C4, so with the 8.8 installed I don't know if the length of the driveshaft changes. Or is there a swap out there that will work? I'm just trying to get my ducks in a row before jumping in.
TBS66 is offline
Old 06-28-2009, 08:30 PM
2+2GT
2+2GT's Avatar
Well, the driveshaft almost certainly changes length, and I guarantee the U joint does. The width is a bit off, and you'll need the Motorsport axle and drum kit to install 5-bolt wheels.
Why don't you just do a 9" instead? It could all be stone-stock then, at least to look at it. That would sure make life easy when you need maintenance.
2+2GT is offline
Old 06-28-2009, 10:15 PM
Scott H.
Scott H.'s Avatar
Scott H. is offline
DCole24
09-11-2015 10:50 AM
91StangOwner
08-20-2015 11:34 PM
Black_GT_02
08-20-2015 01:26 PM
ding56
08-14-2015 02:40 AM
PearlGenPu
08-12-2015 01:57 PM
Quick Reply: 8.8 rear end swap in 66
