seat belt install
Old 07-09-2009, 06:09 PM
ortho1121
ortho1121's Avatar
Default seat belt install
Have 66 convertible. Bought front seat belts but have no clue how to install. Took out driver's seat and there are no visible holes to install the belts. HELP!!
ortho1121 is offline
Old 07-10-2009, 11:57 AM
jay67fast
jay67fast's Avatar
I have had several 67/68's. If yours is engineered the same (and I think it is), You will find a mounting point on the side of the interior rocker panel about midway between the front and back of the seat. That's for the retractor. There is a mounting point on the side of the transmission hump, near the back of the seat, for the fixed end.
BE AWARE, if the carpet has been changed, the holes for the seat belts will NOT be cut out. You will have to find them by loosening the carpet so you can see under it in order to locate and cut the holes for the bolts. Also be aware these are hardened shoulder bolts, grade 5 or higher, and can be bought just about anywhere bolts are sold.
Hope that helps,
Jay67fast
jay67fast is offline
Old 07-10-2009, 06:18 PM
jspagna1
jspagna1's Avatar
J67fast is right on for the hole positions. But not sure, did'nt you have to take out the old ones? Or did the car not have them and someone just laid new carpet covering the holes? You should be able to feel for the holes, if not get under the car and look for them. I have a coupe, not sure if it would be any different with a vert.
jspagna1 is offline
v8sn95
09-07-2015 10:17 AM
TimeLord101
09-04-2015 09:27 AM
cbird1177711
09-03-2015 08:43 PM
Quick Reply: seat belt install
