Supporting mods to get 300HP out of 5.0
Old 07-30-2009, 01:14 PM
5.0mustangaod
5.0mustangaod's Avatar
Question Supporting mods to get 300HP out of 5.0
Hey, Ive got a fully rebuild 302 with only about 100 km on it, i finished it last week. In the mean time, I bought myself a set of Edelbrock Performer 60379 heads. I need some advise on how I will get at least 300 HP out of this motor. Im thinking
- 1.6 Roller rockers
- E303 (Installed)
- Mill the Edelbrock heads
- Upper and lower intake, dont know which one yet
Thats my plan so far, but what else would you guys recommend? Injectors? Fuel rails? Anything would help. And id like to keep it NA for now.
5.0mustangaod is offline
Old 07-30-2009, 01:28 PM
Tony71502
Tony71502's Avatar
Milling brand new heads? Put that all together and throw it on the dyno, first.
Tony71502 is offline
Old 07-30-2009, 01:49 PM
5.0mustangaod
well, i bought them used. But they are in need of a milling, it looks like someone milled in a ring around each combustion chamber for a special type of head gasket that may of had to deal with a turbo or nos.
Old 07-30-2009, 07:02 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
^^^^loc wire head gaskets......anyway, th e-cam will hurt you, you'd max the potential and get close to your goal panding on the intake you chose and I'd get a custom cam to max the combos potential
mjr46 is offline
Old 07-30-2009, 07:27 PM
OneFine89Mustang
OneFine89Mustang's Avatar
agreed...that e cam is outdated...think about a trickflow, comp cam..etc
OneFine89Mustang is offline
Old 07-30-2009, 08:08 PM
Gator
Gator's Avatar
Trick Flow TW heads 170, Custom cam, Track Heat Intake
300+wrhp.
http://sbftech.com/index.php/topic,15152.0.html
Gator is offline
Old 07-31-2009, 12:13 AM
redemption
redemption's Avatar
+1 on TFS1 ive heard my friend has it its got a decent bump and idle to it you should like it =]
redemption is offline
Old 08-09-2009, 11:27 PM
5.0mustangaod
Post
haha, yes i agree the E303 is a little dated but i just rebuild the 302 its got only about 400km on it, hasent even broken in yet, so the motor wont be torn down anytime soon. What do you guys think? U/L intake, 24 lbs injectors, mill the heads, roller rockers? What else can I do?
Old 08-09-2009, 11:29 PM
SonicBlueFiveSlow
SonicBlueFiveSlow's Avatar
Why do you feel the need to mill the heads?
SonicBlueFiveSlow is offline
Old 08-10-2009, 01:52 AM
Hamutoff
Hamutoff's Avatar
shucks, the stock 5.0 H.O. roller cams are not too bad. there was a magizane article in CAR CRAFT where they built a 5.0 and got 400 with the stock cam and aftermarket heads but the thing is that it not fuel injected...
I would say get your heads squared away and get 1.7:1 ratio rocker arms should get you close to your goal. I would say that your fuel rail is NOT going to be an issue at all, nor would I think that the stock injector size would be your limiting factor... I would guess that your lower intake manifolid would be holding you up.
Here is the article:
http://www.carcraft.com/techarticles...cam/index.html
Here is a snippet from the article
If we claimed we could make 400 hp with a stock Ford 302 short-block and the stock factory hydraulic-roller cam, you'd probably say, "No big deal, they're probably using nitrous." What if we said we could do it without nitrous or any other kind of power-adder-totally naturally aspirated, and the only things we'll change are the heads, headers, and rocker arms? Everything else-pistons, rods, cam, oiling system, and so on remains totally stock. We hope you'd be impressed, because we certainly were.
Hamutoff is offline
Quick Reply: Supporting mods to get 300HP out of 5.0
