Head gasket - 66 200ci straight 6
Old 08-06-2009, 11:54 AM
Bugler
Bugler's Avatar
No I don't have a manual. I'll try to find one. And no I have not determined what it is but I figure it's not a long job so I'll do it and change the oil and such and hope it helps. I'm gonna hit as many gaskets in the set I can get in a few hours.
Bugler is offline
Old 08-06-2009, 11:20 PM
tx65coupe
tx65coupe's Avatar
Originally Posted by Stepman
Check the index. All the ones I have, chapter 2 is subdivided into the different engines.
I have this one. I don't see anything about I6 170 or 200 in it.
http://www.mustangsunlimited.com/ite...sp?T1=MP121+01
tx65coupe is offline
Old 08-07-2009, 07:28 AM
wsovonick
wsovonick's Avatar
According to my 1965 shop manual, the max torque for head bolts on the 200 CI is 75 lb. I'm sure it's no different with the 66. I just went through a rebuild of my 200 that included a trip to the machine shop where they sleeved the cylinders and planed the block and head. After everyhing was put back together (my brother's shop did the rebuild) I noticed oil seepage around the head gasket in the area closest to the firewall. One of the old salts on the fordsix.com forum suggested that after the machining, some of the bolts might be bottoming out, thus providing a false torque reading. He suggested that I add hardened washers under all the head bolts and re-torque. After doing that, the leak stopped. You might want to consider having the proper washers handy, just in case, or use them anyway as a preventative measure.
wsovonick is offline
Old 08-07-2009, 11:37 AM
Bugler
Bugler's Avatar
Thanks for that. Any idea what size I should be getting for washers? And since I don't have time to wait, can someone scan and send me pages from a service manual that deal with replacing the head gasket?
I got the head gasket set which includes intake and exhaust manifold, valve cover, water outlet, egr and valve stem seal. Should I do all of that right away or just the head gasket?
Bugler is offline
Old 08-07-2009, 12:19 PM
1slow67
ROTM Moderator
1slow67's Avatar
I would do them all since you will have the engine taken apart.
1slow67 is offline
Old 08-07-2009, 12:52 PM
Bugler
Bugler's Avatar
How long should all of that take for someone who's never seem the inside of a Ford engine?
Bugler is offline
Old 08-07-2009, 01:03 PM
jcoby
jcoby's Avatar
have you rebuilt engines before? replacing all of that shouldn't take more than 2-3 hours if you know what you're doing.
jcoby is offline
Old 08-07-2009, 01:40 PM
Bugler
Bugler's Avatar
Rebuilt the top end of a couple 6 cyl fieros but not something quite this old.
Bugler is offline
Old 08-07-2009, 03:00 PM
  #19
Bugler
Bugler's Avatar
And never anything with a carb.
Bugler is offline
Old 08-08-2009, 08:57 AM
  #20
wsovonick
wsovonick's Avatar
I used 7/16 head bolt washers. The manufacturer of the washers i used is "Mr. Gasket Performance Group" www.mrgasket.com.
Quick Reply: Head gasket - 66 200ci straight 6
