Rubber vs Cork valve Cover Gasket
Old 08-09-2009, 04:41 PM
unit91
unit91's Avatar
Question Rubber vs Cork valve Cover Gasket
Anybody ever use the rubber gaskets? Any better than cork? Do you need to put any oil, etc., on either one of them when installing?
unit91 is offline
Old 08-09-2009, 04:48 PM
2+2GT
2+2GT's Avatar
If you mean valve cover gaskets, I've never had good results with rubber. Since I have solid lifters, R&R of the valve covers is something I've done a lot.
2+2GT is offline
Old 08-09-2009, 05:24 PM
bill_w
bill_w's Avatar
+1 on rubber if you are pulling them off and on, but in my experience tend to squeeze out if not torqued right. If they are staying on, I'd go with the cork held in place with some yellow adhesive....
bill_w is offline
Old 08-09-2009, 05:28 PM
JamesW
JamesW's Avatar
Felpro makes a silicone coated steel valve cover gasket that is reinforced at the fastener holes. you just snug it down and you're good.
JamesW is offline
Old 08-09-2009, 05:31 PM
2+2GT
2+2GT's Avatar
I use the Fel-pro cork gaskets, sealed to the valve covers. With stamped steel covers, this is the best way to get a seal.
2+2GT is offline
Old 08-09-2009, 05:47 PM
67mustang302
67mustang302's Avatar
The Fel Pro rubber/silicone with the steel laminate core and reinforced bolt holes, like James said. You torque it down correctly one time and it's fine, it doesn't swell and shrink and get hard like cork does. I've used both and the steel cored rubber is 10x better, you just have to make sure the mating surfaces are clean and straight.
67mustang302 is offline
Old 08-09-2009, 05:53 PM
cprstreetmachines
cprstreetmachines's Avatar
Re-inforced rubbed is the only way to fly. They do make a black black viton type rubber though that works well with stock thin railed valve covers. You cannot beat steel cored rubber gaskets on a good set of thick valve covers. Off and on. Had the same pair for over 5 years.
cprstreetmachines is offline
Old 08-09-2009, 07:58 PM
CAD
CAD's Avatar
+1 on the rubber/silicone steel core gaskets. They also make an oil pan gasket like that and I've never had a problem with them.
CAD is offline
Old 08-09-2009, 11:31 PM
andrewmp6
andrewmp6's Avatar
I haven't used a cork gasket in 6 years never had a leak on anything.
andrewmp6 is offline
Old 08-10-2009, 11:06 AM
unit91
unit91's Avatar
I googled fel pro gaskets and was directed to JEGS.com and couldn't find any for a 6 cylinder. Only for performance engines. Well, excuse me! Any idea who might have the silicone coated steel valve cover gasket that is reinforced at the fastener holes for a 6 banger? NAPA has a cork reinforced with rubber gasket, and the plain cork.
unit91 is offline
GimpyHSHS
19
12-19-2023 01:12 PM
Dathan
10-05-2015 05:52 AM
winner99
10-01-2015 01:06 PM
Boostaddict
Lethal Performance
10-01-2015 08:58 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
10-01-2015 08:57 AM
Quick Reply: Rubber vs Cork valve Cover Gasket
