Replacing EGR valve & DPFE sensor?
Old 08-14-2009, 12:28 AM
RDP
RDP's Avatar
Default Replacing EGR valve & DPFE sensor?
So I took my 02 Mustang to a Fletcher Auto because the Service Engine Light popped up. They told me that the problem with car was I had a bad EGR valve and DPFE sensor and they wanted to charge me over $400 to fix the problem. I found both those parts at NAPA for under $140 and I have my Chilton manual for my car which explains how to replace these parts and they seem pretty easy/straight forward to replace. I wanted to see if anyone has actually done this and if it is as easy as it looks. Both parts look like they just need unbolted and unplugged and that is about it.
RDP is offline
Old 08-14-2009, 02:30 AM
RyansQuick6
Reverse Gear Member
RyansQuick6's Avatar
Remove the DPFE sensor, spray some brake parts cleaner or carb cleaner in it, let it dry out, re-install it, and you're most likely gonna be all good from there.
***edit***
next time ask here before spending money, you'd be amazed at the things this mob has hidden in their pink matter.
RyansQuick6 is offline
Old 08-14-2009, 10:38 AM
RDP
RDP's Avatar
Thanks, I haven't purchased the parts yet. I just looked them up to see how much they will cost me. But I did have to pay Fletchers to just look at my car, which is lame. All they did was use a scanner thing... I really need to invest into one of those.
RDP is offline
Old 08-14-2009, 12:04 PM
l_shizzle_l
l_shizzle_l's Avatar
I bet they got the code P0401. You might not even need the new EGR valve, replace the sensor and see if that does not fix it. I got that code once and just replaced the DFPE and that fixed it.
Autozone/oriley's has code scanners that you can use for free.
l_shizzle_l is offline
Old 08-14-2009, 03:20 PM
RDP
RDP's Avatar
On the printout the guy gave me from Fletchers it says "P0407 EGR Flow" and "P1401 DPFE CKT"
RDP is offline
Old 08-18-2009, 03:34 PM
2000Stanglover
2000Stanglover's Avatar
I have replaced the senser, i still get the code P0401 i think or might be a different one i'm running off of memory.
2000Stanglover is offline
Old 09-14-2009, 03:37 PM
robinson209
robinson209's Avatar
I was throwing the same code, P0401. I tried to clean the DPFE sensor but it didn't work. After a couple hours of driving the SES light just came back on and threw the same code, P0401. Today I bought a new DPFE sensor and installed it. I'll get back to you guys in about a week. I figure if the SES light doesn't come on in a week then it is most likely fixed. I'll let you guys know so you don't have to spend the money trying to figure it out.
robinson209 is offline
Old 09-21-2009, 07:27 PM
robinson209
Well it's been a week now and the SES light has not come back on. This means the new DPFE sensor fixed the P0401 problem. I got it from Autozone for $35. Hope this helps!
Old 09-21-2009, 08:01 PM
RyansQuick6
Reverse Gear Member
If water had ever managed to seep into it, there's no bringing back to life. Sounds like it's all good though.
Old 09-22-2009, 01:36 AM
2000Stanglover
Well i did the same thing and i still get the code. tried cleaning the lines out. I even checked the egr valve and everything check ok.
Nick Oliver
10-17-2018 04:22 AM
articman
06-21-2018 11:45 PM
5.0muscle
01-11-2016 01:17 PM
bconboy
09-21-2015 12:52 PM
zanemoseley
09-06-2015 12:58 PM
Quick Reply: Replacing EGR valve & DPFE sensor?
