my exhaust smells like farts.... thoughts???
Old 08-20-2009, 12:31 PM
Xeno
'Dr. X'
Xeno's Avatar
Default my exhaust smells like farts.... thoughts???
well, i did a search for this, and found kind of a mix of answers. in my case, i've got an '05 gt, with 18,000 miles.
my thoughts at first were bad cats, but some of the other threads i've found had someone with the same problem, and they had ~25k miles on their car; and everyone thought that was pretty low mileage for bad cats. (maybe there is a hole in one, or both, of them)
next, i figured bad gas. since day one of ownership, i've gotten my gas at quiktrip; if there is anyone who hasn't heard of them, they are pretty much the biggest gas station.... place in the kansas city and surrounding areas, so i am pretty sure they use a decent quality of gas (plus, my parents and grandparents fill up there and i've never noticed the smell in their cars).
then i read that some people suggested going wot to help 'clear' the cats out. well, i frequently go wot, so they 'should' be clear
so... i've kind of ruled out the three major possibilities (even though one of the three could still be the problem). the sulfur/fart smell is present from the first time i turn the key until i shut her off. or, maybe it's normal and i just have to live with it
any additional thoughts would be greatly appreciated (i'm not too fond of holding my breath while driving )
cliff notes: my car's exhaust smells like farts... why?
Xeno is offline
Old 08-20-2009, 12:37 PM
Vectorpat
Vectorpat's Avatar
Maybe your farts smell like exhaust, JK. Do you have a tune on the car sometimes this can effect it. Different fuels can have different smells also. Maybe try another brand and see if it changes.
Vectorpat is offline
Old 08-20-2009, 12:43 PM
domindart
domindart's Avatar
Maybe it IS your farts.
domindart is offline
Old 08-20-2009, 01:11 PM
mynameismike65
mynameismike65's Avatar
Its normal, before I got the o/r prochamber mine smelled like eggs/sulfer. Just loose the cats, it will sound better and smell better
mynameismike65 is offline
Old 08-20-2009, 01:12 PM
Xeno
'Dr. X'
Xeno's Avatar
har har har, guys (i knew i'd get responses like this)
anywho, i don't have a tune (yet) and as far as the brand goes, do you suppose it could just effect one vehicle (since my parents use the same brand and don't have any problems)
do you suppose hi-flow cats would have the same effect (i don't really want the 'uber'-loud exhaust the o/r setups can have).
oh, and on a side note, i have gta exhaust
Xeno is offline
Old 08-20-2009, 01:27 PM
sonicmetalicS197
sonicmetalicS197's Avatar
I have noticed the exact same thing, but only at certian times I haven't been able to notice a pattern or rmp range for the problem yet. I always use Shell V powah gas. I noticed an exhaust leak right under the cabin, where my mufflers are, so I tightened up the clips and that seemed to help alot, cut down on the smell prolly 80% but I've still smelled it like once or twice since then. So that might help, smoke your pipes just to b sure, also check your cai/airbox for leaks I had one on my cai so that might have been a cause too...filer fell off, fuxing K&N that's the 2nd time I think I need to sea foam
sonicmetalicS197 is offline
Old 08-20-2009, 01:36 PM
4LITER6
4LITER6's Avatar
Actually it's your UPPER lip......j/k
4LITER6 is offline
Old 08-20-2009, 02:32 PM
MrSandman
MrSandman's Avatar
If it smells a little like rotton eggs.. it may be the sulfur content in the gas you are using. You can't rule out bad gas until you try a different brand.
Try Shell or BP.. Shell is the best quality in the STL area... maybe yours too. The gas itself is usually the same across brands.. but Shell, BP, etc.. have higher quality additives that are mixed in at the refinery.
MrSandman is offline
Old 08-20-2009, 02:42 PM
Goldenpony
Goldenpony's Avatar
I have seen and used a product to clean catalitic converters. Be worth a shot. I got it at an auto parts place. You just pour it in your tank.
Goldenpony is offline
Old 08-20-2009, 02:56 PM
You haven't thought about fouled O2 sensors. Sensors that are carbonized from running rich can cause false readings to be given to the PCM. Over time this will saturate the Cats.
Quick Reply: my exhaust smells like farts.... thoughts???
