95 gt over heating problem, im puzzled!
Old 08-22-2009, 08:16 PM
kennebellgt
kennebellgt's Avatar
Default 95 gt over heating problem, im puzzled!
I have a 95gt Mustang, mods are in my sig. anyways this over heating problem started about two weeks ago, i replaced the water pump, coolant sensor, t-stat and i flushed the radiator, i stuck a hose in the top radiator hose inlet and water came out of the bottom inlet pretty fast, I then stuck the water hose on the bottom inlet hose and it took awhile for it to come out of the top inlet, but it eventually came out but it seemed like it took a little bit, also the upper radiator hose gets extremely pressurized and the right side of the radiator was cold while the left was hot, seems weird because yesterday both sides were hot as was the lower radiator hose and today it is cold, is the lower radiator hose supposed to be cold? and when it does overheat it doesn't boil water out of the reservoir or anything, anyways i need this fixed any insight would be great thanks guys.
kennebellgt is offline
Old 08-22-2009, 09:00 PM
kennebellgt
ttt for the love of urgency
Old 08-22-2009, 09:45 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
when does it overheat?? stop and go or highway driving
mjr46 is offline
Old 08-22-2009, 10:03 PM
kennebellgt
[QUOTE=mjr46;6439869]when does it overheat?? stop and go or highway driving
stop and go but sometimes highway too
Old 08-22-2009, 10:15 PM
mjr46
mjr46's Avatar
when it overheats is the cooling fan on??
mjr46 is offline
Old 08-22-2009, 10:17 PM
kennebellgt
yes it is on every time. thanks for your help mjr your one of my favorites on here
Old 08-22-2009, 10:23 PM
kennebellgt
im thinking maybe the stock temp gauge? because when it does overheat no water boils, and no water comes out of the reservoir etc etc.
Old 08-22-2009, 10:58 PM
94mustang94
94mustang94's Avatar
my stock gauge just started the same thing. it will read hot but all sensors are new, water pump, t stat, and hoses. so when it started reading hot i put a temp gun on it and it was right at 175 on the intake right by the sensor and 190 on tstat housing. i have heard stock gauges are famous for this
94mustang94 is offline
Old 08-22-2009, 11:03 PM
kennebellgt
yeah im picking up an auto meter water temp. gauge tomorrow, what temp should my car run at?
Old 08-22-2009, 11:09 PM
kennebellgt
where do you point the temp gun when checking the engine temp. ?
Quick Reply: 95 gt over heating problem, im puzzled!
