Cutting rear bumper for dual exhaust?
Old 09-03-2009, 01:38 PM
Ponyboy289
Ponyboy289's Avatar
Default Cutting rear bumper for dual exhaust?
This Saturday I will be installing the Pypes SFM65 dual exhaust system on my '06. For mufflers, I'll be installing a set of GT take-offs. If anyone else has done this, what did you use to cut the rear bumper fascia for the driver's side exhaust tip? I've got the cutting template from Pypes, but it does not have any suggestions for what tool to use. I was thinking of using a Dremel tool with a cut-off wheel. Anyone got any suggestions?
Ponyboy289 is offline
Old 09-03-2009, 03:21 PM
jtstakelin
jtstakelin's Avatar
Before I got my GT bumper, we used a pneumatic body saw. Pro tip, use some blue painters tape to tape the entire area that you will be cutting. this will help prevent the paint from getting chipped. I have a v6 bumper that is already cut that would need to be painted to match!
jtstakelin is offline
Old 09-03-2009, 03:38 PM
157dB
Cut & Paste Expert
157dB's Avatar
a HOT WIRE
stretched inbetween a homemade 2x4 framework.
Heat the wire with a battery charger and heat
your way thro the bumper cover.
Then a wine bottle with some sandpaper
round it will clean the edge right up....
157dB is offline
Old 09-03-2009, 03:40 PM
Ponyboy289
Ponyboy289's Avatar
Thanks for the tip! I was thinking about the blue painter's tape also, just to keep the paint from getting scratched or flaking on the edge of the cut.
My apologies to all the regulars for posting this question. I just did a more thorough search of the site and I see where this topic is a beaten dead horse. From what I've read, it sounds like the Dremel will work fine. Now I've just got try and keep a steady hand while I saw into a $20,000 plus automobile with a tool I bought at Wal-Mart.
Old 09-03-2009, 05:40 PM
Joshspony
Joshspony's Avatar
Originally Posted by 157db
a HOT WIRE
Thats a good idea, I never thought of that. Sounds a little McGiver, but I'm sure it would work really good.
Good luck, have a shot of Jack first to steady your hand!
Joshspony is offline
Old 09-04-2009, 05:15 AM
rls82959
rls82959's Avatar
I used a dremel with a a tiny drill bit for steel. Go slow with the dremel, the plastic is really thin and the dremel will slice right thru it. And yeah, steady your hand and don't take your eyes off the cut.
rls82959 is offline
Old 09-04-2009, 12:52 PM
staggolee
staggolee's Avatar
Don't forget the template: http://pysales.com/inst/SFM68-69-bumper-cutout02.pdf
Granted you did buy it from pypes, but I don't know if they just ship this to you with your product
staggolee is offline
Old 09-04-2009, 10:23 PM
28HopUp
MF Administrator
28HopUp's Avatar
I traced the cut-out onto the painters tape applied to that side. Then I used a razor blade to rough cut the hole close to the line. Finally, I wrapped sandpaper around a full soda can and rotated the can back & forth. It worked great. Just don't slip and cut too far.
28HopUp is offline
Old 09-05-2009, 01:06 AM
HoorayBeer
HoorayBeer's Avatar
dual exhaust will look great. good luck
HoorayBeer is offline
Old 09-05-2009, 08:39 AM
157dB
Cut & Paste Expert
157dB's Avatar
This Saturday I will be installing the Pypes SFM65 dual exhaust system on my '06. I've got the cutting template from Pypes,
Originally Posted by staggolee
Don't forget the template: Granted you did buy it from pypes, but I don't know if they just ship this to you with your product
I think they shipped him a template
157dB is offline
Quick Reply: Cutting rear bumper for dual exhaust?
