Clutch Pedal Diagram picture request.
Old 09-03-2009, 10:43 PM
FuzzyDiceRule
FuzzyDiceRule's Avatar
Default Clutch Pedal Diagram picture request.
Sorry if the title is a little vague, but i am looking for some kind of diagram for the clutch assembly in the Fox Mustang. Im attempting to design a Hydraulic clutch kit for my car (have a Master cylinder, a slave cylinder for a t5 (from a buddys abandoned V8 RX7 project) and an idea of how this is going to go together, but im trying to design a part to actuate the MC using the existing Clutch assembly and Quadrant Mounts. So what i need is a diagram showing distances and diameters of the 2 mounting shafts for the quadrant, as well as the angle difference between idle and depressed, pedal wise, so i can design a part in Solidworks to take the place of the quadrant, and utilize a pushing motion to actuate the MC (instead of Pulling, like the stock setup). Its kind of a long shot, but anybody have anything of the sort? If nothing like what i described, anybody have ANY diagrams of the clutch pedal? Preferrably Profile with depressed and idle in the picture, so i can decipher angles that way? Thanks a bunch guys
FuzzyDiceRule is offline
Old 09-03-2009, 10:57 PM
mattdel
mattdel's Avatar
gonna need a hell of a hydraulic system to make this work. its cable operated for a reason.
anyway i used to have a ford diagram of sorts but i cant find it =(
mattdel is offline
Old 09-03-2009, 11:09 PM
FuzzyDiceRule
like i said, i have a slave Cylinder made for a T5, and its cable operated because of lack of space for a clutch MC (or at least thats how it seems...)
Old 09-04-2009, 10:19 AM
mattdel
mattdel's Avatar
http://www.thatmetalbox.com/automotive/HydraulicClutch/
it's been done using factory ford parts.
mattdel is offline
Old 10-08-2009, 12:11 AM
Hamutoff
Hamutoff's Avatar
yup thats mine... on my site
here is some more info
I have gotten together a mass of parts, I believe that I will end up with two complete kits and some left overs
-4 the truck/van cast bellhousing (blasted and powdercoated)
-2 rubber clutch fork seals, 3 clutch forks
-2 the block plates
-3 pedal assy z bar
-few used hydraulic master/salve complete assy
-adjustible fork pivots
-11" truck clutch assy
Here is some info
http://www.ford-trucks.com/forums/70...ml#post6754056
Here is the Clutch I got:
Brand RAM Automotive
Manufacturer's Part Number RAM-88801
Product Line RAM Premium Replacement Clutch Sets
Input Spline Quantity: 10
Input Shaft Diameter (in): 1.062 in.
Disc Diameter (in): 11.000 in.
Disc Diameter (mm): 279mm
Disc Material: Organic
Disc Style: Sprung hub
Pressure Plate Style: Diaphragm
Throwout Bearing Included: Yes
Throwout Bearing Style: Standard
Notes: Fits external slave cylinders only.
Clutch Kit, Organic, 1 1/16 in. Diameter Shaft, 10-Spline, 11 in. Diameter Disc, Ford,F-150/F-250/F-350 Pickup
Here is the Flywheel I got:
317-FWFM116
# 1967-87 Small-Block 289/302/351W C.I.D 28 oz. External Balance
# 11'' Diameter Clutch
# 164-Tooth
# Only fits diaphragm style pressure plates
Hamutoff is offline
daltron
04-28-2016 08:10 PM
Thunderball
15
11-22-2015 11:49 PM
junior04
09-28-2015 10:53 AM
MacSerio
09-27-2015 01:05 PM
ThatJuanStang
09-25-2015 08:01 AM
Quick Reply: Clutch Pedal Diagram picture request.
